gearbox fluid
hi guys wheres the plug to top gearbox fluid up?
Its on the top of the gearbox, normally brown plastic, with a white pressure release plug in it, however they are sometimes white, black or grey.
As below
[Image: 5741_under_bonnet_2.jpg]
Or you take the wheel off, undo a 19mm i think? On the side casing (the level plug) its towards the bulkhead, and fill up through that until the oil overflows abit
(17-11-2014, 12:22 PM)Seb_Ryan Wrote: Or you take the wheel off, undo a 19mm i think? On the side casing (the level plug) its towards the bulkhead, and fill up through that until the oil overflows abit
Thats the way i have always done them
couple of quick questions as I have also decided to do my gearbox oil.
I know it is 75w80 that I need but what is the best brand and best quality oil?
Secondly do I need to replace the washers on the drain, level, and filler plugs when I remove and replace them?
Thanks
Best oil is the genuine stuff tbh. 9730 AA part number off the top of my head after buying so much lol.
As for the washers, I always forget and they often leak after lol. Also check your driveshaft oil seals, as you'd need to drop the oil again if one needs to be changed in a months time.
I can't find the washers anywhere haha. Or are they just a standard size that loads of gearbox's have?
I think they're the same as engine sump plug washers.
Okie dokie. Cheers mate Smile will get this all done this coming weekend Smile Will probably pop to the nearest peugeot garage and get some washers and a drive seal as well if it doesn't look like a too bad job
(17-11-2014, 09:57 PM)JTaylor2005 Wrote: couple of quick questions as I have also decided to do my gearbox oil.
Thanks
This is peugeot spec & probs cheaper than pug
http://www.amazon.co.uk/Total-BV-Transmi...B008PS2OQ2
The washers for the gearbox im 99% sure are the same as the sump plug for the engine. Pretty sure 31327 is the part number, we stock them at work
https://www.nielsencdg.co.uk/acatalog/To...980_4.html
Can't remember what the postage is though, but that's where I get all my fluids from. Sump plug washers can gotten from Amazon as a job-lot (100+).
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
I normally get 3 or more goes out of a copper sump washer by backing it up with a bit of ptfe tape. The ptfe tape consolidates the joint.
I carefully wrap ptfe tape over the washer and make a very neat job of it.
I roll ptfe tape on my knee to make string. Then I wind a little on the sump plug thread, not over the whole thread, but around the thread immediately in front of the washer ie. make a ptfe ring.
I ensure the joint surfaces are perfectly clean and never ever overtighten.
Steve (saving you 50p)
You can anneal copper washers by heating then up with a blowtorch and reuse them plenty
Any decent motor factors should be able to sell you sump bung washers for pennies.
I'm thinking to change the gearbox oil, is it recomended the TOTAL one, or any difference with the COMMA or Valvoline?And is it 2litres?
It is two litres and i'd stick to the total stuff myself, used comma before and it was awful.
