Threads: 252
7
What do I need when changing rods? New shells and bigend bolts? And where is best place to get them from? Looking to change the 16v rods into a new engine so making sure I know what to look for in advance
Thanks
Also had a VR headgasket fitted not long ago would it be ok to reuse this when heads removed
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 343
15
When I fitted hdi rods to my old engine, I just used same shells and bolts, just make sure there in good condition, my old bottom end is still going in fine to.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
no need to replace bolts or shells if they're in good nick
headgasket on the other hand, yes would change this out
Threads: 252
7
I do now there f*cked lol
Sedan Project
Blaze 1.6 Dead
Threads: 41
Car Model/Spec: Dtractor
can get away with just using a new HG.
Reuse bolts, rod studs, rings, shells, oil, etc etc.
In a no expense spared build these should all be replaced though.
Threads: 29
Car Model/Spec: 205 1.9 TD
Well if you really didn't want to replace the headgasket you could take the crank out
