Threads: 3
Car Model/Spec: 306 Sedan LXDT
So looking at swapping my auxillary setup on my sedan.
Currently has phase 2 a/c setup and want to go for phase 1,
I can get hold of another pas pump, alternator, tensioner and bracket.
Is there anything else i need or any problems i will have?
E.g pas pump not clearing the a/c bracket on current sump?
Thanks in advance
Threads: 371
29
Car Model/Spec: ford fiesta
The sump will need triming with a grinder as the lower brakets wont fit for the pas pump. Also you will need the braket that attaches directly to the block its diffrent to the ac one.
Threads: 4
Why are you changing to a ph1 setup?
Threads: 371
29
I did mine as I had both lying about and the aircon was broke. Seemed to free up some space in engine bay. Looked neater imo. Also have a phase one rad.
Threads: 3
Pretty much same reason as bash, ph2 has stupid tensioner setup and my auto one needs replacing anyway. Just easier having phase win setup!
