Led bulbs
Led bulbs
Just wondering what led bulbs is it for the miles counter and the clock. Don't need the dials as I have plasma dials comming Smile. So I'm going to be a cheap skate and just buy a few Smile.
T5 or 286
1 in the dash lcd
2 in the clock/temp display
Thanks Smile
Be warned of the ones that come in the B8.5 type twist cap, as they do not fit (you can take the LED bulb out and swap in almost everything easily, except in the heater controls
Do have to solder the ones for the lucky windows?
Do I need rounded end or flat?
Apparently flat are less likely to give you a 'hot spot' of light, I had some round ones, and used a permament black marker on the tip, which seemed to reduce the 'hot spot'.
As for 'lucky windows', do you mean the electric switches in the door? If so, yes, I believe you do need to solder/ de-solder them.
giblets Wrote:Apparently flat are less likely to give you a 'hot spot' of light, I had some round ones, and used a permament black marker on the tip, which seemed to reduce the 'hot spot'.
Ok mate thanks for that Smile it helped Smile and yes ment electric windows. Autocorrect on iPhone :p.
Thought they'd have to be soldered Smile thanks.
