Easiest way of fitting the circlip
'evening all,
I finally had the chance to sort the rear brakes out, all apart from this type of circlip.
I was a little hesitant to use force as I didn't want to stuff the new bearing.
How do I get the damn thing in without knackering the bearing, losing fingers or swearing?
(apologies for crappy picture quality)
Just push it in with hand untill its in then tap it down with screwdriverpunch hammer
I got it down to the rim half way down but as one end went down the other came up.
I thought about using a socket but wondered if I could compress it somehow?
Just get a friend to hold one side down as you tap other should be easy never had an issue with them before
circlip pliers???
You cant use circlip pliers on those without the holes...
I haven't had an issue with fitting these though, they literally just push in! Push one side right down, hold it there and then push the ends in...
Well, I feel a bit of an idiot Confused
Thank you BashBarnard and Toms306. After a fresh look at things, the clips went in soft as butter.
All I can think is I was just tired and couldn't see the most straight forward way of doing it.
Ive been there before to tierd to to do anything logically
