	Threads: 90
 7
 Car Model/Spec: 306 Gti6
		This has been really bugging me for a while! It will happily sit just under 90! Soon as I sit in traffic for a while it shoots up! Fans aren't kicking in! But I put water in it yesterday! Drive it down the road and I shoots up to 110 ;/ so I put my foot down thinking that would help! And it was still rising! What the hell is wrong with it!
	Threads: 102
 18
		Well if the fans aren't kicking in that'll be why the temperature is rising.
Have a read around the threads where people have had them fail, often it is the relay.
Be careful driving it, days are very hot lately and you could overheat it and have headgasket failure.
	Threads: 90
 7
		 (18-07-2014, 04:26 PM)RetroPug Wrote:  Well if the fans aren't kicking in that'll be why the temperature is rising.
Thank you! I have been asking for some manly help haha
	Threads: 100
		Think you need to check why the fans aren't coming on and the thermo stat.
	Threads: 465
 114
 Car Model/Spec: Vauxhall
		how often you putting water in?
air lock maybe
	Threads: 18
 10
		If you're having to put water in, I'd be questioning where it's going...
	Threads: 102
 18
		Agree about water loss. Not a good sign.
	Threads: 1
 Car Model/Spec: Supercharged Gti 6
		18-07-2014, 06:02 PM
(This post was last modified: 18-07-2014, 06:02 PM by 6waysforward.)
		To check to see if the fans are working, unplug the green plug on the thermostat on the right hand side of the engine. If they come on then the relays are fine, it could be a faulty bitron on unit.
If they don't come on then it's a wiring or relay fault.
I just re wired my 1st 6 so I could control them.
Alternately as people above have suggest you could have an air lock as this is common on the gti6. Bleed the cooling system properly. There probably is a guide on here somewhere.
If it's not an air lock then you need to look into where it's going.
		 (18-07-2014, 06:02 PM)6waysforward Wrote:  To check to see if the fans are working, unplug the green plug on the thermostat on the right hand side of the engine. If they come on then the relays are fine, it could be a faulty bitron on unit.
Its the brown plug mate
Green plug is ECU temp sender, Blue is dash temp sender and brown is cooling system temp sender
	Threads: 42
 28
BROWN sender, not green, green is ecu.
	Threads: 90
 7
		I took a brown relay off as it was ticking last year.. Oops! Its not loosing water like that guys! Its not circulating properly!
		Relays are supposed to tick.
	Threads: 90
 7
		No, not constantly tbf lol.  Where abouts was it from?
	Threads: 102
 18
		Hang on...a control unit that you didn't know the function of made a noise so you binned it and now you're not sure why some elctronically-controlled things aren't working?! Or am I misunderstanding that?
In any case, replace the thermostat and refill the system and make sure it is bledup properly with no airlocks, and check the fan wiring and control systems like the others have said.
	Threads: 1
	Threads: 90
 7
		I fixedte temperature issue I had water it just wasn't circulating! Need to fix the fan now! And fix the doorhandle that snapped off today haha! The list is getting bigger not smaller
	Threads: 90
 7
		So what we all thought was wrong!! It was leaking the water through a broken hose which had a hole in! Which kind!y Paul (Cully) fixed! Reps to him!!
