Threads: 386
87
Evening,
So, obviously you can see it's not a 306, same 2.0 HDi90 RHY engine though.
Wtf is this whine? It drives fine (on a private road lol as it has no MOT/tax atm) but makes a hell of a whine...sounds like a supercharger tbh lol.
http://youtu.be/c0r0v4M8x28
I'm arguing with myself over what it is...
Turbo? But it boosts well and doesn't smoke at all.
Alternator? But it slows with the engine, whereas the whine 'hangs' for a bit.
PAS pump? Same as alternator, it should slow quickly.
AC pump when free-spinning? Don't think so as I turn the AC on half way through the vid and it makes no difference.
Car has done 85k miles, but been sitting for months due to a starting fault (which I have now diagnosed, thanks Cully ![Wink Wink](https://www.306oc.co.uk/forum/images/smilies/wink.png) )
So what do you reckon the whine is?
Tom
Threads: 62
10
Given 11 thank(s) in 11 post(s)
Check for a woman in the engine bay, they make a rev related whine...
![[Image: wallye-gtd.JPG?raw=1]](https://www.dropbox.com/s/pcxk1pgpaucznvr/wallye-gtd.JPG?raw=1)
HDi Owner for 200k/9 years
Threads: 386
87
A woman? What would one of those look like?
Threads: 386
87
No-one any idea??
Only idea I've had from the 206 forum is crank pulley but that cant whine surely? Just knocks afaik?
Threads: 19
12
30-05-2014, 09:07 AM
(This post was last modified: 30-05-2014, 09:08 AM by mr_fish.)
idler pulleys gone dry for the aux setup? sounds similar to what I had on my hdi
Threads: 386
87
Did that hang after the revs had dropped though? I can't see how anything aux related wouldn't slow immediately as the revs drop off?
Threads: 19
12
Listening to it again, does seem strange that it does that.
May have to pop the aux belt off and just have a feel/spin of the pulleys/pas/alternator and see if you can tell if one component isn't quite right.
Threads: 386
87
Yeah, that's the next thing to try I think.
Threads: 59
3
Car Model/Spec: 306 D-turbo
Is it that a dturbo 206 would you be interested in selling?
Threads: 202
58
Drop the aux belt off and see if it stops. Failing that, leave it until it causes an issue?
Threads: 386
87
(31-05-2014, 12:06 AM)Jtrigga Wrote: Is it that a dturbo 206 would you be interested in selling?
It's a GLX... So gets more spec than the dturbo lol.
Threads: 386
87
(31-05-2014, 06:58 AM)Jonny81191 Wrote: Drop the aux belt off and see if it stops. Failing that, leave it until it causes an issue?
Yes removing the aux belt is the next thing to do, been slightly side tracked by the stupid drum brakes on it.
Access is even worse than the 306 for getting at the belt though lol, not only is it tight, they've also put the ECU loom and some coolant pipes right where you need the spanner on the sprung adjuster!
Threads: 386
87
Turns out its easier to get at the sprung tensioner from underneath.
Found out it's the alternator making the noise, it appears to have some sort of one way clutch so it only spins one way, allowing it to slow down much slower than the engine itself. Now not sure if its a fault or if its just normal alternator noise that would usually be covered by engine noise!
Threads: 91
83
(31-05-2014, 11:14 AM)Toms306 Wrote: Turns out its easier to get at the sprung tensioner from underneath. ![Wink Wink](https://www.306oc.co.uk/forum/images/smilies/wink.png)
Found out it's the alternator making the noise, it appears to have some sort of one way clutch so it only spins one way, allowing it to slow down much slower than the engine itself. Now not sure if its a fault or if its just normal alternator noise that would usually be covered by engine noise! ![Confused Confused](https://www.306oc.co.uk/forum/images/smilies/confused.png)
Yeah, was just about to suggest that..
Quite common now, it's to stop the belt flapping - as it's the magnets going past the windings that effectively make it shake since it's a 6 pole - you get 6 shakes per rotation, so essentially it decouples it and allows free play.
Threads: 386
87
Ah, makes sense, good idea really. Would you say the noise is normal for one then?
Threads: 91
83
No, that sounds excessively loud.
My V50 has one, doesn't make that racket - sounds like the bearings shagged in it.
That's how they're put together if anyone's interested.
Threads: 386
87
Oh right, fair enough. The 206 isn't turning out to be the bargain I expected lol.
Threads: 476
81
Car Model/Spec: 306 Rallye
Must be the straight cut gears
Threads: 4
Prob the pulley, mine was a bit noisy but replaced it and the aux belt
Threads: 26
4
Given 6 thank(s) in 6 post(s)
New pulleys arent to dear, but you need a special kit to take them of.
Threads: 591
54
Some of the late HDi's had those fancy alternators... Very different whine to usual.
Threads: 386
87
Bit of a thread revival, I don't even own the car anymore.
Threads: 142
58
Car Model/Spec: E46 BMW 320d
Yeah, i know....new user making their way to 20 posts.
I've got it covered, seeing as i'm the only Mod online at the moment! Should be getting ready to go out tonight!
Threads: 581
195
Threads: 142
58
Oh i don't know, Fooby has been around an awful lot the last couple of days....kinda unnerving actually! Was beginning to wonder if he'd lost his job or something!
Threads: 581
195
(05-07-2014, 06:31 PM)WiNgNuTz Wrote: Oh i don't know, Fooby has been around an awful lot the last couple of days....kinda unnerving actually! Was beginning to wonder if he'd lost his job or something! ![lol lol](https://www.306oc.co.uk/forum/images/smilies/legacy/lol.gif)
Nah. He just remembered the other day that he owns a forum
Threads: 142
58
