21-06-2014, 12:58 PM
![[Image: auto-part-ball-joint-for-peugeot-306-good-quality.jpg]](http://images.gasgoo.com/MiMwMDRfMDA0IzMwNjM5NDEwMA--/auto-part-ball-joint-for-peugeot-306-good-quality.jpg)
Right that is a 306 balljoint. The bit with the 3 holes sits inside the end of the wishbone. You want to measure from one of them bolt holes to the ball joint pin its self. I bet you will find that the one on the side your having troubles with is shorter than the other side. If so, replace the ball joint (only about £15 from ECP) with one for a PAS car.
so I wanna measure from the centre of the hole to the centre of the ball joint pin like this?
