timing belts..
Doing the head, so might be a good idea to do the belt too (it is a good idea i know)
have 2 choices..
kit from pug, or kit from local motorfactors
any issue with using a good quality OEM one? or should i roll some Darwins up and spend for a pug one?
also, are there any differences in tooth count between the XUD variants? mine is an XUD9SD (turbo, cat, no IC) from a citroen.. best to check before as pug thinks its a (if i remember correctly) 136 tooth
/Toseland
Depends on the motor factor one if its a Gates or Continential it will be fine, if its a linglongshongchong i would be sceptical.
~I always use a motorfactors kit, usually a continental belt plus gates pulleys/tensioners
Belts are the same across the range, even fit the XUD7 I believe
HDi Cabby Project Click
Gates, Continental, Dayco are all the very best.
theres 2 different types of idler pulleys and waterpumps though.
gave the local motorfactors the number of it.. they use GATES kits so comes with the gates belt and associated peices.
/Toseland
Can't go wrong with gates tbh
(05-06-2014, 03:43 PM)Frosty Wrote: Can't go wrong with gates tbh
+1 ThumbsUp
