Has anyone got a electric die grinder I can borrow for a week or 2? Of course beer tokens/sexual favours will be given
21
21
Threads: 130
82
Car Model/Spec: 106 GO-NAD
got a dremel, that do the same thing?
edit: figure you're using it to gasket match your head right? it'll work, my mate used one on his bikes. feel free to borrow it for a bit if you like
samass Wrote:got a dremel, that do the same thing?
edit: figure you're using it to gasket match your head right? it'll work, my mate used one on his bikes. feel free to borrow it for a bit if you like It's for porting my head so don't think a dremel will be up to the job. Cheers anyway!
Threads: 130
82
yeah thats what i thought it was for, as said, my mate used one for the head on his motorbike, up to you tho. feel free to borrow it to try if you like, mines pretty top notch so is fairly powerful
samass Wrote:yeah thats what i thought it was for, as said, my mate used one for the head on his motorbike, up to you tho. feel free to borrow it to try if you like, mines pretty top notch so is fairly powerful
What size collet is on it?
Threads: 130
82
got a multi chuck on it, up to bout 2mm or something i think, can't find my verniers to check 100%.
got shitloads of attachments tho, loads of sanding barrels with really coarse grit ones, they can chew through pretty much anything
samass Wrote:got a multi chuck on it, up to bout 2mm or something i think, can't find my verniers to check 100%.
I'll get back to ya on that one. Need to see if I can get the right bits in 2mm then because so far I've only found them in 6 and 8mm. Cheers!
Threads: 130
82
fair nuff man, just let me know!
what bits is it you need?
Threads: 541
124
Ive got a dremmel (well halfords equivalent) and it definately wont be up to the job but you can borrow if you need.
Oh and dont get the grinding bits for a drill cos theyer shit too
Dum-Dum Wrote:Ive got a dremmel (well halfords equivalent) and it definately wont be up to the job but you can borrow if you need.
Wasn't going to. Would be a right PITA using a drill! I might just go and buy one but it's like 90 quid and then I will probably never use it again haha
Never mind. Just won a 110v one on eBay for 30 quid. Bit of luck my neighbour is a electrician one side and a builder the other. Need a transformer now!
Threads: 130
82
I'd say bargain, but I really have no clue haha
samass Wrote:I'd say bargain, but I really have no clue haha
Well most of them I was finding were 80 upwards so yeah
Threads: 130
82
In that case, bargain!
