Threads: 129
11
25-04-2014, 07:37 AM
(This post was last modified: 25-04-2014, 07:38 AM by strictly_perv.)
I'm back in the 306 game once again, after saying never again. I'm sure you all understand.
So the car, it's a GTI-6 converted to an XUD from a 406 which is good as I get the '6 spec but an Eco engine. When I got the car it ran mechanically sound but was an unfinished project so have done lots if niggly bits to get it to a decent enough standard.
The spec:
Obviously GTI chassis so 283 brakes ect ect.....
XUD engine with 9mm Bosch (off my old 205) and k14 soon to be FMIC
Lowered
Deep dish wheel
Wind deflectors
A few other bits and bobs so will update when I remember
Some if you may recognise the car but here's a few pics
Stage 2 XUD Sedan
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
So whos was this before?
Looks good.
Threads: 92
5
Car Model/Spec: Subaru 20.d, GTi 6, 205 xs
Given 3 thank(s) in 3 post(s)
Misstap?
Current cars
Subaru Impreza 2.0d - Daily
Threads: 129
11
Yeah Misstaps, my sisters old car
Stage 2 XUD Sedan
Threads: 266
18
Sweet, know it's been looked after then!
Threads: 465
114
Car Model/Spec: Vauxhall
i have the 6 engine and ecu that came out of that car
Threads: 476
81
Car Model/Spec: 306 Rallye
awww forum car!
Threads: 91
83
Glad to see this thing back!
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
25-04-2014, 01:08 PM
(This post was last modified: 25-04-2014, 01:09 PM by ginge191.)
(25-04-2014, 10:25 AM)Ruan Wrote: Glad to see this thing back!
Amen
Getting it to any shows this year???
Phaes 1 GTI 6 - Onyx Black
Threads: 448
51
Good to see a project thread up
You looked right at home in it when I last saw you haha!
Threads: 19
12
didn't think I would be seeing this beast again....
Whats the plans?
Threads: 129
11
Plans are a general tidy up, fit the FMIC kit I bought and maybe fit the GT20 that's sat in the garage. After destroy various turbos and engines I really want to be sensible this time round  yawn.
Since I've owned it I've replaced the aux belt, handbrake cables, fixed the fans and hot wired the high speed fan to come on with the AC button, fixed the speedo and re-tuned the pump as it was set up for the K04 powered 205 but slightly de-tuned so it had chronic coal.
Stage 2 XUD Sedan
Threads: 102
9
nice to see you back, but you need to build another good hard core Dturbo like the 205 was!
Threads: 129
11
Wish I could, but need to keep this sensible and reliable for work....sad face.
Stage 2 XUD Sedan
Threads: 35
7
Car Model/Spec: Phase 1 dturbo sima blue
Given 2 thank(s) in 2 post(s)
Still looks good every one always goes back to the 306
Threads: 29
18
Car Model/Spec: mx5 mk1 1.8
I'm glad she is still in the family... Plus, I can't wait to drive it after all the work you have done/are doing on it
Threads: 129
11
I've got an intercooler kit, any ideas for the best route to take it as it has a GTI rad with a built in expansion tank like the hdi's.
Stage 2 XUD Sedan
Threads: 581
195
Where are the outlets on it?
Threads: 129
11
It's just a cheapo eBay special side entry one.
Stage 2 XUD Sedan
Threads: 110
20
Car Model/Spec: Estate, DT, GTI6 and 205
Given 30 thank(s) in 30 post(s)
I think there is a bit of room on passenger side of the rad to go thru. Think 2" pipe fits thru it ok. Pretty sure the rad is the same as ph1s Dturbos
Threads: 61
11
Looks great
white and diablo really go.
Threads: 591
54
Nice to have ya back....
Threads: 448
51
(02-05-2014, 05:45 AM)Frosty Wrote: I think there is a bit of room on passenger side of the rad to go thru. Think 2" pipe fits thru it ok. Pretty sure the rad is the same as ph1s Dturbos
This
Threads: 129
11
04-05-2014, 07:11 AM
(This post was last modified: 04-05-2014, 07:11 AM by strictly_perv.)
Thanks Frosty, I bought a 2" kit, it's what I've always used.
When I had the sedan I just put the pipes over the rad which looked identical to this one, not ideal as rad was leaning back. I could always chop into the slam panel?
It's running no cooler at the moment and even at stock boost levels I can really feel the heat soak :/ need to get this on ASAP
Stage 2 XUD Sedan
Threads: 169
91
Given 1 thank(s) in 1 post(s)
Nialls cut into his slam panel to go down the front of the rad. Quite a good route TBF.
Threads: 129
11
I might do that then, like this but cut the slam panel out a bit
Stage 2 XUD Sedan
Threads: 136
11
What's that front mount off of?
Threads: 581
195
(04-05-2014, 07:32 AM)Grant Wrote: Nialls cut into his slam panel to go down the front of the rad. Quite a good route TBF.
It is a good route but very tight. Also my rad is now moved back 10mm at the top lol
Threads: 129
11
That's a forge cooler, had it on 3 cars, another before my ownership but I believe it came off a Derv Doctor FMIC kit from years back.
Niall, how much did you cut out the panel?
Stage 2 XUD Sedan
Threads: 581
195
[attachment=15971]
That much
