Do I need a new clutch?
Want to replace my clutch at the end of the month but before I spend loads of money getting it done I want to make sure it needs replacing.
These are the issues I'm having:
When I pull away it's a little slow and doesn't have a strong pull.
And when I'm accelerating quickly the revs pick up but my speed doesn't.
Is this definitely in need of a new clutch?
Thanks Smile
Sounds like it, yeah.
(23-04-2014, 11:19 PM)Curt Wrote: Sounds like it, yeah.
Cool I'll get it done the end of the month Smile
Is there clearance in the clutch pedal? If its solid from the top could be the clutch cable as there self adjustin. Seen this on a partner and was causin clutch to slip.
(24-04-2014, 08:43 AM)daveylennon93 Wrote: Is there clearance in the clutch pedal? If its solid from the top could be the clutch cable as there self adjustin. Seen this on a partner and was causin clutch to slip.
The pedal is hard from top to bottom, I'm going to get the cable replaced at the same time
Clutch might be fine so, could be just the cable. If i was you id get the cable done then see if its alryt. Save a few ££££
When you do change the clutch, replace the clutch fork bushes as well.
Hmm dunno if it's worth getting the clutch and the cable done so at least I know it has a brand new clutch for me to start driving with
