Threads: 386
87
18-03-2014, 04:36 PM
(This post was last modified: 18-03-2014, 04:36 PM by Toms306.)
Hi guys,
You may've seen in chatbox but I replaced the cambelt, waterpump and tensioners today (306 HDi).
After 2 manual turns, the belt is wandering a few mm off the pulleys away from the engine, but the timing holes still line up perfect.
Ruan suggested I remove the tensioner and idler and clean behind them. Unfortunately this hasn't made a difference. Everything was torqued correctly as well.
So any more ideas? As I haven't got a clue what try next. Wish I hadn't bothered tbh lol.
Tom
Threads: 18
10
Car Model/Spec: 3 x 205 GTi & 306 HDi
Usual cause of this that I've seen is something running mis-aligned so that it's not square to the belt and other pulleys. Really doesn't need to be far out at all to make the belt slowly work its way off - I remember someone's 205 doing the same thing after an engine rebuild and that turned out from memory to be that the head had been skimmed on the piss.
Waterpump would be my best guess if you're sure it was OK before hand and all you've done is belt/tensioners/waterpump.
If you haven't yet filled it with coolant and you've still got good access, swap the original bits back on one by one until the problem goes away - bit of a pain, but atleast you'll know what the issue is there.
Threads: 386
87
Hmm, ok, effort lol.
It was a genuine waterpump though, and torqued to Haynes spec, so should be alright I'd have thought? Unless I've put too much instant gasket on it, but that wouldn't be 'solid' enough to hold the pump out surely?
Threads: 2
Car Model/Spec: 306 Cabriolet Hdi Stage 1+
18-03-2014, 06:06 PM
(This post was last modified: 18-03-2014, 06:07 PM by R1-Mini.)
Did you put the bottom pulley back on while trying to turn over by hand?
If not then that might be the reason why as it helps keep the belt in line
I always put the bottom pulley back on and nip it up
Threads: 62
10
Given 11 thank(s) in 11 post(s)
As above, was bottom pulley on?
![[Image: wallye-gtd.JPG?raw=1]](https://www.dropbox.com/s/pcxk1pgpaucznvr/wallye-gtd.JPG?raw=1)
HDi Owner for 200k/9 years
Threads: 90
54
As above, is bottom pulley on AND tight?
does the wondering occur on both cam and HP pump?
Threads: 386
87
18-03-2014, 08:06 PM
(This post was last modified: 18-03-2014, 08:08 PM by Toms306.)
Threads: 90
54
Put the crank pulley on, tighten bolt, turn engine by hand twice, problem will be fixed.
Cheers n gone
p.s the crank pulley and bolt is what holds the lower belt pulley in against the block / belt on.
Threads: 386
87
18-03-2014, 08:10 PM
(This post was last modified: 18-03-2014, 08:17 PM by Toms306.)
Ahhhhh shit.
Spent hours trying to figure this out as well!
Cheers Darren and others!
(18-03-2014, 08:09 PM)darrenjlobb Wrote: p.s the crank pulley and bolt is what holds the lower belt pulley in against the block / belt on.
Ah right, I knew the bolt held both pulleys, and did put that back to turn the engine with. Didn't realise the aux pulley acted as a guide though, but makes sense now you've said!
Was the first cambelt I've ever done anyway (never did one at college on mechanics course lol), so besides the aux pulley fail it went well, will know for next time at least!
Threads: 33
7
Car Model/Spec: Diablo PH3 2.0HDI
(18-03-2014, 08:10 PM)Toms306 Wrote: Was the first cambelt I've ever done anyway (never did one at college on mechanics course lol), so besides the aux pulley fail it went well, will know for next time at least!
It's all a learning curve
Threads: 386
87
18-03-2014, 09:14 PM
(This post was last modified: 18-03-2014, 09:14 PM by Toms306.)
Yeah, it definitely is James. Was really worried about it if I'm honest, getting timing out or tension wrong....but so far the hardest part was removing the bloody covers!
*Cue a thread about valves meeting pistons tomorrow.
Threads: 236
36
Car Model/Spec: '01 HDi DTurbo
More confident seeing you get this done tom. Would be something I'm keen to do myself too as can't justify the cost of getting it done by a garage right now.
![[Image: Sig500x130.png]](http://i430.photobucket.com/albums/qq25/chris_rx71/Sig500x130.png)
Threads: 21
3
Car Model/Spec: Stage 3 HDi
Given 5 thank(s) in 4 post(s)
(18-03-2014, 09:29 PM)C.A.R. Wrote: More confident seeing you get this done tom. Would be something I'm keen to do myself too as can't justify the cost of getting it done by a garage right now.
Once you understand the principal behind locking the cam and loosening the 3 13mm bolts to allow the pulley to float its a very easy job
Threads: 465
114
Car Model/Spec: Vauxhall
(18-03-2014, 11:57 PM)HDi--Power Wrote: Once you understand the principal behind locking the cam and loosening the 3 13mm bolts to allow the pulley to float its a very easy job
be warned though dont over tighten those 3 13mm bolts on the cam pulley as that is what fractures the pulley! then over time the pulley will break up
que thread: my pulley has broken what do you think caused it
Threads: 386
87
They're 20Nm according to Haynes.
This seems ok now, since fitting the lower pulley lol. Havent actually started it yet though, not sure I dare.
Threads: 226
24
Car Model/Spec: A3 TDi
Do it!!
