Threads: 11
Car Model/Spec: 306 1.8 Auto, 2.0 Meridian HDI
Hey all,
I thought I'd rack everyone's brains again,
How do I remove the headlight on a phase 2?
The issue being the passenger side headlight aim mechanism I believe has detached itself from the reflector inside the assembly and before I run at it with a socket set, screwdriver and a hammer I thought is ask if there's any tricks techniques or methods to get it out without giving it any more reasons to fail its first MOT in over a year...
Hope you guys can help!
Cheers
Threads: 11
After reading your project page I thought you'd reply first! :-) brilliant buddy! Now one more question how do I get the hockey sticks off?
Threads: 465
114
Car Model/Spec: Vauxhall
You don't need to remove the headlight to refit the leveler motor.
Check to see if it has detached, turn the motor anticlockwise, and it will pullout if it's detached.
If it's still attached when you pull it, it will still be attached to the lenses mirror.
The trick to reattach the ball into the lens mirror is to remove the bulb cover at the rear and push the reflector with your finger so the thing tilts, so you can push the ball of the leveler motor into its slot hole in the reflector
Threads: 11
Thanks all for the help, loving this forum already!
i used Cully's method and found the problem.
I'm pretty sure thats meant to be attached. Ha
Threads: 11
Haha, well i'm using some of bostiks classic "Extra Strong Super Glue" which has less integrity than blue tack....
I'll get one up with as many pictures as i've got, i'm rubbish taking photos of progress..
