stereo half powering
Hi all just a quick question? I have a aftermarket stereo in my 306 it wont power up properly but will eject cd and if i press a button the time comes up. Any ideas what the problem is. It worked fine and ive tried another stereo that works and same problem. The only noise i get is the relys clicking alot
Sounds like a bad earth or other dodgy connection ... :-)
So i assume it doesn't turn on with the car but you can turn it on manually wether the cars running or not? If so, your shunt fuse is in the wrong position.
If it just doesn't turn on at all but still ejects CDs. Sounds like your switched live isn't connected properly.
It wont power on at all. I did have the fan hooked to it. Could i usb burnt out a wire
Is the memory wire the only one getting power then (allowing it to eject cd's)and It sounds to me the switched live isn't getting power atall.
Sounds about right ive no way of testing which have power bar putting my tounge on it and hoping for the best haha
The fan hooked on it? What fan? Have you checked your fuses?
No fuses checked yet and engine fan wont kick in unless connected to battery or live so wired to stereo to turn on
That just sounds like a huge bodge to me. I do hope you have just wired the relay activate cable to it and not the actual fan power cable otherwise it wouldn't surprise me if you have melted all the cabling!
(17-01-2014, 04:45 PM)Niall Wrote: The fan hooked on it? What fan? Have you checked your fuses?
+1 what fan? D:
(17-01-2014, 04:49 PM)sillywotsit1993 Wrote: No fuses checked yet and engine fan wont kick in unless connected to battery or live so wired to stereo to turn on
+1 what fan? D:
errrr i wonder Sam? Wink
+1 what fan? D:
engine fan and cables not melted everything is working fine other than the stereo
+1 what fan? D:
I'm not a retard. The engine fan post was posted while I was writing mine!
But yes that sounds like a massive bodge. Of all the places to get a live you got it from the stereo Sad
Turns out it was a fuse and also found out theres more fuses blown under the bonnet
(21-01-2014, 08:07 PM)sillywotsit1993 Wrote: Turns out it was a fuse and also found out theres more fuses blown under the bonnet
No surprises there with that bodge
Its all repaired now no problems it was a temp fix to move it
