Threads: 36
2
Car Model/Spec: PH2 Dturbo
Wel changing to clutch on the dturbo, got the passenger driveshaft out, drivers side is being a right c word..
I know there is 2 driveshaft bolts that have to be rotated, which i have done, but no avail.. its still in there.
Also, anyone know how many bolts should be holding the gearbox to the engine? i've managed to find and remove 6 so far.
Threads: 195
6
Car Model/Spec: 2000 Xs 1.8 16v
you will find one at the bottom near the back pointing towards the box. I no this one is a allan key head
Threads: 36
2
is that the one that the head of the bolt is pointing towards the bulkhead?
Threads: 42
28
no, its pointing towards the right side.
Threads: 195
6
16-01-2014, 08:22 PM
(This post was last modified: 16-01-2014, 08:22 PM by underground375.)
You will find that ones next to the where the drive shaft gos in. the one your looking for it lower down. The head of the bolt is pointing towards the engine
Threads: 36
2
alright i'll have a look, anyone shed any light why the drivers side driveshaft isnt budging either?
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
My old one, we removed the lower mount it goes through, and when off the car, a good 30 minutes with a sledge hammer just about budged it.
don't forget to remove the top pin on the clutch lever arm to give you that little bit more leverage on the g.box
Phaes 1 GTI 6 - Onyx Black
Threads: 28
3
Given 1 thank(s) in 1 post(s)
The middle bearing on these can be difficult to shift, particularly if it hasn't been disturbed before. If you have the hockey stick bolts rotated and everything else clear, then a cold chisel and lump hammer should shift it eventually, but it can be hard work.
'95 Peugeot 405 GLX with XU10J4RS and ITB's
'97 Peugeot 406 1.9TD with TD04
'05 RenaultSport 182 Cup
Threads: 151
14
Car Model/Spec: 306 D-turbo
When box is off get a peice of wood on the end of the driveshaft and give it a smack with the hammer
Grease the bearing up with copper grease or something like
Best to get it out now and grease it up while it's easier to get out be good practice for if it needs to come out again
Team Doesn't own a 306
Threads: 127
33
Car Model/Spec: ZX Volcane TD
16-01-2014, 11:26 PM
(This post was last modified: 16-01-2014, 11:29 PM by zx_volcane.)
Blimey sounds like a right farce!
Only four bolts holding the box on - three go in one way screwing into the block, and the bottom one at the back goes in the opposite way screwing into the box
Driveshaft sometimes takes a knock with a hammer and punch to move the intermediate bearing if its a bit seized, but shouldn't hold the box on as its going in the opposite direction and won't be fighting it if you're pulling the box off.
Hope you've got something supporting it, they're not light and you don't want it suddenly dropping on any part of you if it suddenly decides to let go!
Threads: 226
24
Car Model/Spec: A3 TDi
I just used a punch and a lump hammer on the intermediate bearing and out it came.
Threads: 35
3
You rotated the two bolts enough? Or maybe one has fallen back into place ?
CONVOI EXCEPTIONNEL
Threads: 151
14
Even if it has fallen back in the shaft will move a little bit, will be seized in and need to do as I said above
