Threads: 65
Car Model/Spec: china blue gti6
So i was sitting in traffic and my car would unexpectedly rev up to about 3000, then calm down to normal, it did this about 4 times, it then made a horrible vibrating noise when i hit boost while chucking out grey smoke, it then revved uncontrolably even when i turned the ignition off, i managed to kill the engine by covering the intake, is the cause of this a blown turbo?
Threads: 39
Car Model/Spec: P2 Dturbo
yea sounds like oil is getting in from somewhere and causing it to run away
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped
95' 306 P1 DT - Onyx - Scrapped
97' 306 P2 DT - Silver - Scrapped
97' 306 P2 DT - Onyx - SORN awaiting scrap
Yep, I'd put money on that being a failed turbocharger.
Few points - don't ignore these otherwise you're likely to end up with a screwed engine also:
- DO NOT START IT until you've removed the failed unit.
- Remove the Intercooler, manifolds and ALL associated pipework and clean it thoroughly - if you don't all that oil that was in there from the failed turbo will come up as soon as the new turbo spins up for the first time, and blow it ALL down the inlet in one go - probably causing a rod failure - I've seen precisely this happen two or three times!!!
- Check Oil feeds and drains for anything suspicious - that could be the reason the old unit failed.
Threads: 65
Okay, cheers, anyone got a turbo for sale? ;-)
Threads: 19
I have a k14 you can have for £20.
though your near darren, would of thought he might have something kicking around...
Threads: 65
Yeah gonna try and get hold of Darren, is the k14 simply a bolt on, or do I need any adaptors. I've got a t2 on ATM
Threads: 65
Any advice on best way to get rid of all the gunky oil thats in the inlet and intercooler?
Threads: 65
Okay mate, will let you know if i need it.
Threads: 80
Car Model/Spec: hdi estate bus cherry red hdi
Will mate I got a parts washer at work if you give my the bits I will do it for you. Also why don't u get a turbo off one on the scrap 306.
Threads: 65
A parts washer? May already have one on the way. Plus it means I have to take it off the scrap 30
Threads: 80
Good point what u going to get going bigger or know? And parts washer for washing out all ur black gunk
Threads: 65
Aright, nah, just going standard, wanna get her back on the road ASAP
Threads: 80
Let me know if u need a hand
Threads: 80
Radd on where u gonna strip it to at your
