Threads: 1
Car Model/Spec: 306 HDI estate
Hello everyone,
I have a W reg 306 HDI estate.130000 on the clock. It's been a reliable workhorse and a superb family car for camping trips, wet dogs, moving the family's junk, dad's taxi etc.
Recently I've heard a squeak from the rear suspension. I took it to a garage and up on the ramp it appeared that the squeak was coming from the drivers side end of the torsion bar. There is no movement in the wheel and the mechanic told me there was nothing to worry about.
Could any members offer me advice on how to stop the squeak. Would spraying wd40 on the area help or are more extreme measures required.
I'm no mechanic.
Threads: 1
(31-12-2013, 10:48 AM)Piggy Wrote: Welcome
Could be a shocker squeaking...that would be the simple solution
Otherwise its the beam bearings...is there any bad camber?
Tyre wear is even. How can i measure camber?
Have a look from behind, you'll know!
Threads: 1
31-12-2013, 12:14 PM
(This post was last modified: 31-12-2013, 12:15 PM by Misterjeff.)
(31-12-2013, 12:09 PM)SRowell Wrote: welcome to the club. estates are becoming more popular so youll fit in well here
Thanks. I really like the extra space. I've got two big dogs so the back has a dog guard and waterproof liner. This means i can keep the seats clean(ish) for the humans. I love the 2.0 HDI engine.
(31-12-2013, 10:54 AM)Grant Wrote: Welcome along
Thanks. Looking forward to chatting to you all
81
Yeh its probably nothing to worry about. As long as the rear trailing arms isnt wobbly and also if the beam isnt showing any signs of camber.
Most of the beams/rear brakes squeak when parked up. Its a fairly standard thing.
Threads: 1
(03-01-2014, 08:21 PM)SRowell Wrote: Yeh its probably nothing to worry about. As long as the rear trailing arms isnt wobbly and also if the beam isnt showing any signs of camber.
Thanks for the advice everyone
I can't see any camber on the wheel but it squeaks when driving. It's only audible at low speeds as engine noise covers it when I speed up.
I think I'll run it for a bit to see if it gets worse. I was just concerned that it might indicate a collapsed bearing or something dangerous.
Threads: 6
Hello and welcome. Changes the bushes is my suggestion. They aren't dear.
Paul
Threads: 5
Welcome to the forum lad enjoy
