Threads: 591
54
ok...so as some may know I have had constant issues with my oil cooler...some my own doing...some not.
But do I need one??
Oil temp never goes above 95degrees on the gauge no matter how hard I drive it
Im thinking of sacking it off and plumbing the heat exchange unit back in
Threads: 17
4
Car Model/Spec: 2000 HDi Wagon
Ooooor you could have it hanging out the front grille in a rat esq style.
That would be big WIN!
Threads: 591
54
Threads: 343
15
Car Model/Spec: 106 gti / 306 hdi estate
Given 3 thank(s) in 3 post(s)
You say the oil temp never goes over 95degrees, but is that with the cooler or not? If it is with cooler I would expect the tempture to raise with out it, I'm looking at oil cooler for 205 so will keep my eye on this thread
Threads: 19
12
I considered running an oil cooler but my temps only hover around 95 degrees even after a blast.
I'd disconnect the pipe work and trial the heat exchanger.
Threads: 591
54
Thats what Im going to do.
it nornally sits around 85/90.
But when the car was overheating all the time it still never went above 95...hit it once.
Whats the sort of temp it should be at?!
Threads: 91
83
Christ, I could quite easily see 120*C+ oil temperatures after a brief hoon.
You should ALWAYS keep the heat exchanger - that's because it warms the oil up faster also, it's a two way thing of heating the oil when cold quicker and cooling it down when it's hot...
You want the oil temperatures around the 90*C mark during normal running to allow any water that's gotten in to eventually steam off...
Threads: 591
54
cool...
It was a secondary question that I wonder if the oil cooler was keeping things too cold!
thanks for input ruan
Threads: 132
4
Car Model/Spec: 305 and 306 HDi's
Given 6 thank(s) in 6 post(s)
Why not get a thermostatic plate or an in line oil thermostat before the cooler that way you've covered all angles?
Threads: 19
12
(13-12-2013, 02:25 PM)Ruan Wrote: Christ, I could quite easily see 120*C+ oil temperatures after a brief hoon.
Probs my crappy guage, though I have a homebrew/hybrid cooling system
Threads: 591
54
(13-12-2013, 04:19 PM)Sambarker Wrote: Why not get a thermostatic plate or an in line oil thermostat before the cooler that way you've covered all angles?
coz they are line £50...
and its done nothing but drop oil because of it!!
this car is supposed to be a reliable GT not a track weapon!
Threads: 90
54
Heh id deffo say keep it...Without a cooler my car would last about 10 minutes on boost...the oil gets raped in big turbo dervs...
Threads: 86
2
Given 1 thank(s) in 1 post(s)
keep it, why are you having issues mate? my mocal cooler was fine, never leaked once!
Threads: 132
4
(13-12-2013, 04:55 PM)Piggy Wrote: (13-12-2013, 04:19 PM)Sambarker Wrote: Why not get a thermostatic plate or an in line oil thermostat before the cooler that way you've covered all angles?
I suppose £50 is a lot of money to spend for some people.
Perhaps if you had proper pipes made up it might be better. I don't recall mine leaking once.
Threads: 91
83
I can't understand anyone having issues with oil cooler hoses unless they're jubilee'd
Which they shouldn't be.
Jubilee clipping HP oil lines is a recipe for disaster.
Threads: 252
7
Car Model/Spec: Xud sedan/Xud estate
Given 2 thank(s) in 2 post(s)
That seems quite low after a thrash mine goes up from 90ish to well above 110 after even a short blast
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 127
33
Car Model/Spec: ZX Volcane TD
14-12-2013, 02:09 PM
(This post was last modified: 14-12-2013, 02:09 PM by zx_volcane.)
Hmmm interesting, without a cooler my oil doesn't seem to get that hot - 150F ish cruising and maybe 190F after a hoon
so whats that 60 - 90 Celcius?
Threads: 129
11
I always planned to fit one to my boosted XUDs but never got round to it, it's up for sale though
Stage 2 XUD Sedan
Threads: 591
54
(13-12-2013, 09:15 PM)Ruan Wrote: I can't understand anyone having issues with oil cooler hoses unless they're jubilee'd
thats not the issue I have had this time!
see my other thread!!
