Threads: 252
7
Got a new rad phase 1 off a s16 but it don't have the oil cooler outlet the one that points towards the passenger side on the back. Is there anyway around this? Maybe pipe it into the top pipe instead?
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 465
114
Car Model/Spec: Vauxhall
sounds like you need a GTI6 rad
Threads: 252
7
Ye so are all s16 fads different ? Might just bond the pipe on
Sedan Project
Blaze 1.6 Dead
Threads: 465
114
think the 6 is the only one with the oil cooler take off in the centre left of the rad
not sure others even have the oil cooler
Threads: 252
7
Dturbo do all ones iv had anyway come like that standard. Might be able to do something tho. Take it off other rad maybe
Sedan Project
Blaze 1.6 Dead
Threads: 42
28
phase 1 DTurbo rad is similar.
Threads: 132
Given 6 thank(s) in 6 post(s)
I've got a ph1 nissens rad for a dt
Threads: 90
The ph1 DT rad has it.
Just T it into the lower rad hose.
The engine simply uses the oil cooler as an "extra" feed from "rad" to "water pump"
Threads: 252
7
Ok cheers so its not a return
Sedan Project
Blaze 1.6 Dead
