GTi6 steels
apparently you need tapered bolts to fit gti6 steels onto a 306? if so could I just use the tapered bolts I currently have on my OZ superTs?
also is 195/50/15 the correct size tyre for these?
thanks Smile
If they have the flat washers welded on them then the idea is you can use flat bolts or tapered bolts as the inside of the washers are tapered.
If you are wanting to use tapered bolts best thing is to give them washers a quick blow with a hammer/chisel and then you should be left with normal holes which take tapered bolts.
