Dturbo just died
Dturbo just died
Now then Folks Im in a bit of a muddle!!!
This morning i went out to my Ph1 Dturbo and it fired up lovely from putting the new glowplugs in ang tightning up any jubilee clips!!!
BUT about 5 seconds after firing up it sudenly stopped runningAngry!!!
I lifted the bonet to have a look around and noticed the grenade had no fuel in it at all so i primed it back up but it still wont fire up!! Why would there be no fuel in the grenade??? I am suspecting the lift pump might have packed up!!!
Any help would be great
There is no lift pump in a XUD. There will more than likely be an air lock now, does the grenade get hard once pumped up?
Yeh it gets hard once pumped
yeah sounds like you're getting air in somewhere Smile
Try the bleed nipple on the fuel housing.
I will check the bleed nipple when i get home and i will also check the grub screw on the side of the filter housing aswell just incase Thanx guys
If your on about the white 1 dont touch that lol
(18-11-2013, 01:38 PM)Seb_Ryan Wrote: If your on about the white 1 dont touch that lol
that's probably where it's leaking from though tbh . .Smile
Ok it dose look a bit britle to be honest so I won't touch that one
So i checked the bleed nipple when i got home and everything is all tight!!
The grenade had emptied the diesel out again so i pumped it up till it was hard only when i let go i could hear a very faint noise like air was being sucked in!!!
There will be an air leak somewhere most probably the fuel filter housing
[Image: av5ym8.jpg]
I think the Grenade has had it so i have ordered a new on and some new Fuel hose aswell.
Lets see if that sorts it. it sounded like the air was being pulled in through the grenade so i susspect a little pin hole or something
Welcome
