Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
I like the idea of having a van with a fairly simple Bosch/TD04L XUD in.
Whats the one to look for in terms of spec/simplicity of engine change?
I have a donor phase 1 D8A 306DTurbo with a T2 & bosch already on.
Berlingo?
Partner?
Any engine thats easiest to swap from (for speedo, rev counter etc)?
Threads: 87
48
old Dispatch . . . had a 1.9 nad in it i believe . .
Threads: 266
18
Just to clarify it doesn't have to be a massive van. Hence why I thought Berlingo/Partner would be a good choice. Much like the 306oc support wagon IIRC!?
Threads: 202
58
XUD NAD was a stock engine in the partner, common as muck and it's already got the correct engine mounts and loom.
TU engined berlingo, cheap as chips because nobody wants them lol.
Threads: 46
A low and boosted Citroen c15 would be win.
Threads: 541
124
Nah you want an ldv pilot, rwd ftmfw.
Threads: 266
18
Threads: 48
Why have you not bought it already?
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Threads: 266
18
(13-11-2013, 02:09 PM) Anton Wrote: Why have you not bought it already?
Wasn't expecting to dish out £200 on ARP studs this month..
Threads: 202
58
Er, bargain much?
Especially as you'll be ditching the engine.
Get it bought!!
Threads: 266
18
Theres no contact number so I've emailed them mine.
Threads: 19
If I hadn't of put the XUD in the 206, I would of liked to put one in a Partner. High boosted LCV
Threads: 266
18
13-11-2013, 03:47 PM
(This post was last modified: 13-11-2013, 03:48 PM by silverzx .)
Viewing/buying the van tomorrow.
Whos keen to help me swap the 1.9TD in then?
He said it smokes white constantly, he's been told its an injector problem.
Threads: 19
(13-11-2013, 03:47 PM) silverzx Wrote: He said it smokes white constantly, he's been told its an injector problem.
just needs a good old fashion drive around the block....at high rpm...
Threads: 266
18
(13-11-2013, 04:35 PM) mr_fish Wrote: (13-11-2013, 03:47 PM) silverzx Wrote: He said it smokes white constantly, he's been told its an injector problem.
Or a 75 miles / 2 hour 20 minute A/B road bash all the way home.
Not that it matters as the 1.9TD lump would be going in!
What suspension do these use? Same strut assembly as a 306?
Torsion bar on the rear?
Threads: 208
60
Given 5 thank(s) in 5 post(s)
Need i say any more trent???? get on it!!!
Thumbnail(s)
Threads: 119
15
Car Model/Spec: Ph1 Diablo DT
Front end is 306 suspension on a Zx estates chassis it's around an inch narrower at strut tops. Uses 405/206 style rear beam. Fair few bits need swooping from the 306 to make it fit
www.prestige-auto-care.co.uk
Threads: 132
Given 6 thank(s) in 6 post(s)
Threads: 5
Car Model/Spec: 306 2.0 HDI
I hope this turns into a project thread!
Threads: 42
28
it literally IS a 405 rear beam on these, as is the Xsara picasso...
front end as mentioned from bulkhead forwards is all 306.
engine wise it'll drop straight in.
Threads: 266
18
Decided to give this van a miss.
- 100 miles / 2:20 hour away.
- Long list of MOT advisories from last year.
- Higher tax bracket (£215 year despite being 51 plate)
- Zero service history (bar the clutch/gearbox reciept which is worthless)
- Struggling to find a lift.
Turns out a friend of mines father just scrapped a mint Berlingo for £120 that he's owned for 12 years, gutted I missed it!
I'll keep an eye out locally but for now this is going under the carpet..
Threads: 19
Car Model/Spec: Xantia HDi shed
I still like the idea of a Dispatch with a high-boost XUD in it.
