Threads: 16
Car Model/Spec: Phase 3 DTurbo
Is there any other cars that have the same one.
My one only charges the battery when over 2K revs. So looking to get another one.
Threads: 42
28
check the small wire is connected.
Threads: 16
yes i checked it, and its connected. it does have a cut in the wire about 20 cm back from the alt. and can see the wire, which looks dark. possible problem. suppose i could put a choc bloc in and see what happens,
Threads: 6
Car Model/Spec: 306 Estate, Meridian 1.9td
Mine failed a few weeks back, so i got this one, genuine valeo with warrenty
http://www.ebay.co.uk/itm/221017878272?s...1497.l2649
Threads: 91
12
Car Model/Spec: 306 D Turbo
Have a look at the ones from the old 406 xud's. I believe they had a higher rated output....
