	Threads: 252
7
Car Model/Spec: Xud sedan/Xud estate
	Given 2 thank(s) in 2 post(s)
		Got given a headunit for my sub in the estate just a basic setup. It has 1 pair of pre outs but there labels "back" as in back speakers but there is no "sub" labeled preout like past units I use.
Can these be used for subs or will it just try using my sub as a speaker
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
	Threads: 171
46
	Given 1 thank(s) in 1 post(s)
		Considering you were given it id just head down to halfords and get a cheapish one with sub pre outs to save the hassle
	Threads: 82
27
		It'll probably be fine, if you're running them with an amp just set that channel to low pass filter and it'll only play the bass notes anyway
	Threads: 591
54
		there maybe a setting choice in thr headunit menu to switch to sub output
however you should be able to set the amp suitably
	Threads: 252
7
		I tryd to read the manual online but could not find anything mentioned about them at all
Sedan Project
Blaze 1.6 Dead
	Threads: 36
2
Car Model/Spec: PH2 Dturbo
		Just put them in, and put the AMP in LPF like Midnight said. Should be fine.
