Headunit pre outs
Got given a headunit for my sub in the estate just a basic setup. It has 1 pair of pre outs but there labels "back" as in back speakers but there is no "sub" labeled preout like past units I use.
Can these be used for subs or will it just try using my sub as a speaker
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Considering you were given it id just head down to halfords and get a cheapish one with sub pre outs to save the hassle
It'll probably be fine, if you're running them with an amp just set that channel to low pass filter and it'll only play the bass notes anyway
Ye amp to 1 sub.
Blaze 1.6 Dead
there maybe a setting choice in thr headunit menu to switch to sub output
however you should be able to set the amp suitably
I tryd to read the manual online but could not find anything mentioned about them at all
Blaze 1.6 Dead
Just put them in, and put the AMP in LPF like Midnight said. Should be fine.
