	Threads: 226
24
Car Model/Spec: A3 TDi
		I thought HDi dont really have headgasket issues?
Dont you do the coke bottle trick?
	Threads: 119
Car Model/Spec: MG ZS180
		Yeah but I don't have much luck sometimes! I can never get on with the bottle way, prefer to blow into the overflow, its also a damn sight quicker.
	Threads: 119
		Hmm, its also slowly using water, I've had to refill the header probably 4 times in two months after doing my cambelt.
	Threads: 226
24
		Stick a hose pipe in the header tank with a wet towel or something round the end to sort of seal it.
	Threads: 226
24
		Its effectively a much stronger version of what your doing except with less air.
	Threads: 119
		Ok may try that next week whilst I'm doing other stuff to the car.
		I'd be surprised if you're still seeing issues with bleeding this long after, sounds a lot like hg. It is very rare on the HDis, but not the first i've seen.
	Threads: 119
		Just going to keep driving and see how it goes
	Threads: 186
38
Car Model/Spec: MG ZR VVC
		07-10-2013, 05:29 PM
(This post was last modified: 07-10-2013, 05:29 PM by lolsteve.)
		Have seen a hdi in the scrappy that looked like it had hgf, but again seems very rare on these engines
	Threads: 6
Car Model/Spec: Rover 214si
		I have seen a few, usually caused by air locks/improper bleeding of the coolent system i find.
	Threads: 119
		After driving home from work today I took off the bleed screw from the matrix (I wore protective gloves etc before anyone says anything!) And it shot out with a lot of pressure, I then refilled the tank and bled it out again at both points, will see what happens when I drive it again. My only concern is having to top it up with coolant once every two weeks during the winter is going to cost a fair bit of money..
