3.0 306 v6
Help please people anyone can't bleed rad
2lt coke bottle fill it with water stick it in the hole, open the bleed points one by one starting from the bottom and working up, keep open until you get a constant stream of water.
Also wrong section.
(29-09-2013, 05:36 PM)Tom Wrote: 2lt coke bottle fill it with water stick it in the hole, open the bleed points one by one starting from the bottom and working up, keep open until you get a constant stream of water.
Also wrong section.
Thanks tom tried that anyone local and fancy poping out
Also wrong section.
It's easy as above make sure the bottle has a good seal mate.
Is the system pressurizing tho?
Sounds like your not doing it right, or it doesnt need bleeding and you have other issues.
Hi again. heater get hot ... Just seems like it gets to hot to quick so am gessing it just fans so will fit some and take her for a test run Wink
How old is your radiator? There crap even new
Does the rad get hot? Could be shagged stat.
"hot"...how hot??
as already asked...does the rad get hot....ie is the stat opening and rad flowing?
what fans are fitted?
