	Threads: 343
 15
 Car Model/Spec: 106 gti / 306 hdi estate
	Given 3 thank(s) in 3 post(s)
		right guys just took cambelt cover off and the cambelt is fine and intact    suspecting cam failure but as said no nothing about these so will get a vid up of the noise it makes soon
	Threads: 386
 87
		Or take the cam cover off and have a look?
	Threads: 343
 15
		 (02-09-2013, 03:12 PM)Toms306 Wrote:  Or take the cam cover off and have a look?
I've got front one off all looks ok, screws are mega tight on rear one and starting to round off    off to work now so will have another look tomorrow. Be nice if it something simple doubt it tho being a Peugeot
	Threads: 102
 9
		id post up on the gti 6 forum fella, as it may just be a simple and easy fix.
	Threads: 151
 14
 Car Model/Spec: 306 D-turbo
		Let me no next time your investigating and ill pop over
Team Doesn't own a 306
	Threads: 343
 15
		 (02-09-2013, 04:00 PM)Danny2009 Wrote:  Let me no next time your investigating and ill pop over
Will do Mate probably be Thursday now as busy for next few days
  (02-09-2013, 03:50 PM)procta Wrote:  id post up on the gti 6 forum fella, as it may just be a simple and easy fix.
Will have to sign up. Worth a try tho....
Will make a thred in the engine section tomorrow with a video of the noise it makes
	Threads: 151
 14
		02-09-2013, 04:13 PM
(This post was last modified: 02-09-2013, 04:13 PM by Danny2009.)
		No worries drop me a text mate ill pop over
	Threads: 11
 1
 Car Model/Spec: Ph3 Meridian HDI
		02-09-2013, 05:46 PM
(This post was last modified: 02-09-2013, 05:47 PM by bigtone0777.)
		Oh dear, stop turning it over when you know it's not right, you'll only end up doing more damage if there's something seriously wrong =-O
Get the second cam cover off and make sure alls ok, take the plugs out and turn by hand to make sure everything moves as it should and at the right time before you even think about turning the key!
Hope it turns out to be a simple fix for you :-)
	Threads: 78
 49
		Yeah, you need to find out what has actually gone before continuing to spin it over/taking vids.
	Threads: 343
 15
		 (02-09-2013, 06:12 PM)Curt Wrote:  Yeah, you need to find out what has actually gone before continuing to spin it over/taking vids.
Yer I get the point but think the damage bas been done when it went bang. I will have a look later on in week and update no rush to get it sorted got plenty to do on 106 first
	Threads: 169
 91
	Given 1 thank(s) in 1 post(s)
		Not really mate. You could have just bent a valve or two. Continue to keep running it and you risk puncturing a piston or snapping valves.
	Threads: 226
 24
 Car Model/Spec: A3 TDi
		If you dont give a shit then time it up and see if it'll go lol
	Threads: 11
 1
		 (02-09-2013, 07:48 PM)Tom Wrote:  If you dont give a shit then time it up and see if it'll go lol
But if it hasn't done the belt then it should already be timed..........unless it's jumped teeth somehow
	Threads: 343
 15
		 (02-09-2013, 07:59 PM)bigtone0777 Wrote:   (02-09-2013, 07:48 PM)Tom Wrote:  If you dont give a shit then time it up and see if it'll go lol
I haven't touched the belt, was speaking to the women I got it off earlier and she said she was comeing off the motorway, when there was a big bang and it died, the recovery guy said it was the cambelt they never checked it tho, and she rang round garages telling them what had happened and that the recovery guy said it was cambelt so said it would be to much to fix, hence her scrapping it.
A few people have said it could have possibly jumped teeth so I need to check, but I wanna get the rear cam cover off first to check the cam. I believe if there was any damage done thing what ever went bang as she came of the motorway would have done it. If timing is out my plan is to time it right and see if it goes. And go from the're but the chances are the valves are already bent.
I got the car cheap so no matter what happens not really fussed just wanted to try and save it from the scrappy. Also would like to drive a 6 just to see what it's like lol
	Threads: 226
 24
		That was my next question if you've took the cambelt covers off and confirmed the issue. Get them off and have a look, i want to know whats wrong.
	Threads: 36
 18
 Car Model/Spec: DT
	Given 2 thank(s) in 2 post(s)
		Tow it again with the 106 at 50 and bang it in gear.
I will either work or catastrophicaly die.
On the 306 waiting list.
	Threads: 386
 87
		50?  Its a 106 NAD.....
	Threads: 36
 18
 Car Model/Spec: DT
		Find a hill?
	Threads: 386
 87
	Threads: 11
 1
		02-09-2013, 08:42 PM
(This post was last modified: 02-09-2013, 08:48 PM by bigtone0777.)
		 (02-09-2013, 08:13 PM)Tom Wrote:  That was my next question if you've took the cambelt covers off and confirmed the issue. Get them off and have a look, i want to know whats wrong.
 (02-09-2013, 03:09 PM)Chris_90 Wrote:  right guys just took cambelt cover off and the cambelt is fine and intact   suspecting cam failure but as said no nothing about these so will get a vid up of the noise it makes soon
Timing belt not snapped :-P
Lots of edits due to being unable to drive tapafail :-[
	Threads: 343
 15
Yer I'm gonna get them off completely but it's such a fiddly job was annoyed after removing 3 screw lol
  (02-09-2013, 08:17 PM)Jake Wrote:  Tow it again with the 106 at 50 and bang it in gear.
Car struggled to pull it at 30mph    the 106 struggles to get to 50 on its own lol
	Threads: 59
 3
		Maybe the tensioner has gone that is also quite common.
