Interference
Today i noticed i have a whine through my speakers (amped) which gets higher in pitch with the revs. Not quite sure what it is tbh! Anyone got any ideas on how to stop it because its driving me bloody insane Sad
Where have you run the cables for your speakers?
[Image: images?q=tbn:ANd9GcS-iKZxKIdeJAUhjnlj3GF...qToWSkt66A]
thats the Alternator
check your battery and earth connections if that dont help
add a 2uf supresion capacitor across the + at the alternator and ground
from the stereo down the passenger side. Its only just started and i havent disturbed any wires in ages though.
(16-08-2013, 06:43 PM)cully Wrote: if that dont help add a 2uf supresion capacitor across the + at the alternator and ground
Yeah that's exactly what I was going to suggest. Took the words right out of my mouth!
ahh, fair enough, in that case, try cully's advice. Big Grin
(16-08-2013, 06:43 PM)cully Wrote: thats the Alternator
I knew you would come through for me. Your like my rock. My one and only.
cheers x
Can you answer my central locking problem now pweeeeese cully? <3
i expect you will get the same noise from the windscreen wiper motor and maybe the cabin fan or even the fuel pump
you might have to fit supressors to each if you have a sensative amp
(16-08-2013, 06:53 PM)cully Wrote: i expect you will get the same noise from the windscreen wiper motor and maybe the cabin fan or even the fuel pump
But why would it suddenly start. Unless the amp is on the blink? Can i not fit a suppressor to the amp?
you need to supress the source of the noise!
you could try fitting ferrite coils to the amp signal wires as they are the ones picking up the interferance
ferite coils being the same thing thats moulded to computer monitor video cables
and grunt ive replyed Big Grin
Not a bad idea. Lucky ive got loads of them from work last week Wink
Cheers x
Did you fix the noise?
Cars been off the road for a while so havent tried yet. Got a few ferrite coils from work so will try them at some point today. Not sure if i will fit the rca through the coil though Sad
