Threads: 26
Car Model/Spec: 205 Mi16 and 306 HDI
right i have been searching to try and find some info but keeps coming with the same old stuff
I need find some info of going the TD04 route.....
The main im worried about is the lag?
OR what else would you bolt? not after big bhp just something better the my standard shagged turbo
Threads: 202
58
I don't mean to cause an argument, so bear with if this comes across a bit off, but you clearly haven't looked in any detail at the XUD section, there's loads of threads similar to this, with other suggestions on choosing the right turbo.
If you're concerned about lag and want to keep near to stock driveability with more power then there's a couple of turbos that have been used that will deliver exactly that. Come back and ask questions once you've gathered more info.
Threads: 25
1
Car Model/Spec: Dturbo
This thread gives some idea of costs and the RR results at the top of the page will give you an idea of figures for a given turbo;
http://www.306oc.co.uk/forum/thread-16288.html
Threads: 100
12
Car Model/Spec: 306 dturbo Ultra Spec
Won't be much lag if any.
My t25 was not that laggy and the td04 is better according to most.
Threads: 115
How can this fool miss the turbo thread that's already up. Anyway what you want is probably a GT15, bolt on, no lag modern turbo, no issues.
Threads: 26
Option A, Buy a GT15, K03, K14, T2, They all bolt straight on, sorted.
Option B, Pick a turbo, make plates to adapt, bolt on, hoon.
just found this...
cheers for the reply's
Threads: 100
12
C: buy my td04 with plates but find an actuator.
Threads: 26
I asked about TD04 because my bro got one cheap
Threads: 202
58
You're looking at 3k before it's fully on blow, quite laggy IMHO
Threads: 26
Cheers Jonny that what i wanted to know
So not getting a TD04 then
Threads: 25
1
Bear in mind that although it doesnt get full boost until 3k rpm its probably still forcing more/ similar air than a t2/K14 etc at lower rpms.
I wouldnt have specific nr's but i dont find the lag to be a problem. It drives much better off boost than say a k14.
Threads: 86
2
yeah, td04/t25 are fine to drive tbh..
Threads: 226
24
Car Model/Spec: A3 TDi
(11-08-2013, 09:02 PM)padge Wrote: yeah, td04/t25 are fine to drive tbh..
Agreed mines easy to drive.
Threads: 4
1
12-08-2013, 09:06 AM
(This post was last modified: 12-08-2013, 09:06 AM by con67.)
If thats much work to drop a gear that it makes a car 'undriveable' maybe some people would be better with an autobox?
Threads: 266
18
Car Model/Spec: 205 DTurbo
(12-08-2013, 09:06 AM)con67 Wrote: If thats much work to drop a gear that it makes a car 'undriveable' maybe some people would be better with an autobox?
This.
Threads: 87
48
boom bitches . . . . . . .spread that on your toast and chow down . .
Threads: 171
46
(11-08-2013, 08:19 PM)306Puggy Wrote: How can this fool miss the turbo thread that's already up. Anyway what you want is probably a GT15, bolt on, no lag modern turbo, no issues.
Wind your neck in calling the guy a fool
You're not one to talk
Little bit of politeness goes a long way
