10-08-2013, 09:10 PM
This is the spec for my Peugeot 306 D-Turbo Phase 2 1998.
TAX TILL December 2013
TEST IS UNTILL JULY 2014
HAS DONE 150 THOUSAND MILES WITCH IS NOTHING FOR THESE ENGINES
RECENTLY FITTED
GTI-6 FRONT BRAKES
REAR DISK BEAM WITH NEW DISK, PADS AND CABLES
DROP LINKS
SMOOTHED AND PAINTED FRONT BUMPER
Timing belt kit and tensioners
Water pump
Bottom arm
Valeo clutch
Clutch cable
Ball joints
Interior:
D-Turbo S Half Leather Pattern Seats. CURRENTLY ONLY HAS 2 FRONT SEATS IN BUT I DO HAVE THE REARS
HDI Clocks and Surround
Stick Shortened
Hdi gear stick
SHOW CAGE
Exterior:
PH2 smoothed Front Bumper
Hdi Crystal Headlights BLACK MASKS
Gti-6 skirts
Colour coded bumpers
Smoked rear lights
GTI-6 CYCLONE ALLOY WHEELS
COIL OVERS ON FRONT
Engine:
1.9 Dturbo @ 20PSI
Garrat T25 Turbo
Bosch Pump, tuned and ground lda
FMIC (front mount intercooler)
HDI gearbox
Pipercross filter
Straight through stainless steel exhaust with twin powerflow back box
GTI-6 Brakes
BAD POINTS!!!!!!
Has a blue boot
front passenger window not working
Rear panels not the straightest but one panel is getting done in the body shop
RECENTLY FITTED
GTI-6 FRONT BRAKES
DROP LINKS
Water pump
Bottom arm
Valeo clutch
Clutch cable
Ball joints
Interior:
Stick Shortened
Hdi gear stick
SHOW CAGE
Exterior:
Gti-6 skirts
Smoked rear lights
COIL OVERS ON FRONT
Engine:
1.9 Dturbo @ 20PSI
Garrat T25 Turbo
HDI gearbox
Pipercross filter
GTI-6 Brakes
BAD POINTS!!!!!!
Has a blue boot
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Ph3 perv cab heaven
Black ph1 XUD died
![[Image: DSC_0190-Copy_zpsf093f84d.jpg]](http://i1038.photobucket.com/albums/a468/167gti8/DSC_0190-Copy_zpsf093f84d.jpg)
![[Image: tapatalk_1427020983519_zpsnwvozlhb.jpeg]](http://i768.photobucket.com/albums/xx328/annegg5511/Mobile%20Uploads/tapatalk_1427020983519_zpsnwvozlhb.jpeg)
![[Image: Untitled-1_zpsc57da38e.jpg]](http://i112.photobucket.com/albums/n180/w1n_2006/Untitled-1_zpsc57da38e.jpg)
