24-07-2013, 07:10 PM
		if you were to make your own exhaust by buying pipe in sections, what angle/lengths would you need? not including the downpipe.
					exhaust Q
		24-07-2013, 07:24 PM
		I think you would need to layout a std exhaust and measure it all mate.
bit of your time and a pen/paper and tape! Wishes for more power...
		24-07-2013, 09:47 PM
		Look here.
http://306oc.co.uk/forum/thread-3849-page-4.html And here. http://306oc.co.uk/forum/thread-1170-page-13.html I think Jonny has made a couple now, he would be the best to help :p
		24-07-2013, 09:49 PM
(This post was last modified: 24-07-2013, 09:50 PM by Jonny81191.)
		You need the following (for an estate, assume the same for a sedan?)
2m straight pipe (you only need 95cm IIRC for the main centre section, but it's worth having the spare for the back etc..) 1x 45* bend 2x 60* bends 1 15cm flexi section 1x welded 90* tight radius bend (if you have a tdo4 or similar with a side facing exit) a backbox of some sort. Top one is off my estate with a rear exit GT20, the bottom one is off Carl's sigma TD04 XUD Welding and fabrication projects undertaken, contact me for more information.
		24-07-2013, 09:56 PM
		Thought you were having one made up?
I think all you would need would be two 60 degree bends and we could only get the straight pipe in 2 meter lengths with some left over, so not sure exactly how much you would need. I'd double check the angles, as I can't remember exactly
	Daily Slag: http://306oc.co.uk/forum/thread-3849.html
Track Slag: http://306oc.co.uk/forum/thread-8873.html
		24-07-2013, 09:57 PM
(This post was last modified: 24-07-2013, 09:58 PM by Jonny81191.)
		My list is correct, just checked the part numbers
It is also worth buying a mandrel bent 90* to chop up to make small bends where needed. or if you're not that fussed about flow you can just cut pipes at an angle. Welding and fabrication projects undertaken, contact me for more information.
		24-07-2013, 10:28 PM
		I only want it from the downpipe, as I already have a downpipe made, just need the rest onwards to the back.
		24-07-2013, 10:33 PM
		In that case, 2x60* bends, about 1m pipe, and a box.
		25-07-2013, 12:29 AM
		Erm, all of them? as in both?
		27-07-2013, 07:49 PM
		Think it goes less than that in places.
How much did that cost you roughly Jonny?  |
