Methanol Kit £50
Methanol kit I was gonna use on my car, but have not had time to fit it - now going abroad so not needed.
Has two nozzles, one 2.0 GPH, and one 2.25GPH. Some pipe, and a sureflo 125psi pump.
[Image: P7150217_zps44db12fc.jpg]
These are not typical alcohol injection nozzles, they are just oil burner nozzles, but do the same job. They will need to be mounted how you see fit though (I was gonna drill a hole in the side of a boost pipe and mount up, or have it positioned before the big turbo).
heres a video of me testing it this evening;
A boost switch need to be added to the kit, but these can be found on ebay or just make one with a boost can like I was going to do.
As the kit is not fully complete £50 + postage.
Dave
How would this activate and start firing at the right time?
Silver Five Door D-Tuurbo'! More Doors More Whores y0! Wink
(15-07-2013, 11:12 PM)RhysBoost Wrote: How would this activate and start firing at the right time?
put a micro switch on full throttle? . .Smile
That or some kid of circuit with a resistor that works via throttle % if you want it gradual like... I need to find someone who has methanol injection and know what kind of difference it makes :/
you would need a BIG tank to manage that...its usually a switch that once you are either passed a certain throttle position, like 70/80% or better still, once you reach a boost pressure
They are driven off boost pressure, you cant have it on throttle position else 5th gear at 30 mph, plant foot and it'll just bog out.
I was gonna make a switch with a boost can so would just close a relay once boost can reaches a contact, could also set pressure this way or use mbc etc.
