Threads: 63
26
Car Model/Spec: GTi6
So, basically when you are at a slow pace or stand still and you turn the steering wheel, either side of dead centre it feels like something is trying to stop you turning, then sort of releases as you keep turning and becomes free again, until you get to the opposite side.
It only does this just slightly either side of centre, as illustrated by this amazing artwork:
The straight line being dead centre.
There's no noise when it happens, it just feels like something is stopping you from making it then freeing up.
I've checked where possible, looked for shit stuck on steering rack or whatever.. nothing there. What else would cause this?
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
12-06-2013, 03:01 PM
(This post was last modified: 12-06-2013, 03:01 PM by ginge191.)
Your swaughans are hungry?
Phaes 1 GTI 6 - Onyx Black
Threads: 169
91
Given 1 thank(s) in 1 post(s)
You being parked against a kerb trying to turn the wheels, then snapping a track rod causing it to free up again?
Threads: 581
195
Any noises from the PAS pump when you turn the wheel? Checked the level of the PAS fluid? Sounds similar to mine was when it was only running on what was left in the lines and i lost all PAS in corners....helpful!
Funnily enough this was shortly before my PAS ram literally exploded on a roundabout sending me in the wrong direction..... have fun
Threads: 63
26
No the PAS level is full, I topped it up before the MOT as it was basically empty.
Great, really look forward to that then.
Threads: 169
91
So do you have a PAS leak if it was neary empty? Could be air in the lines and the pump pushing fluid through to get the steering back light again
Threads: 143
10
Car Model/Spec: Ph3 XUD
Given 8 thank(s) in 8 post(s)
Did you bleed the system? Go from lock to lock a few times.
Threads: 169
91
TRE's arent royally f*cked?
Wishbone ball joints/topmount bearings in good nick?
Threads: 78
49
Wishbones are like 6 months old, top mounts around a year when the coilovers went on, PAS was fine after I put Ed's pump on with no leaks and the level was fine last I checked.
I don't really know what you're on about, so I suggest MTFU. Maybe change your jeans and try again?
Threads: 122
9
Car Model/Spec: Kingfisher Ph1 Dturbo S
Given 7 thank(s) in 7 post(s)
We have replaced a few of the universal joints that go onto the rack frombthe column at work they sieze up making it hard to sterr every other 90 degrees if that makes sense
Would almost put money on it being that
