Threads: 2
Car Model/Spec: 306 D turbo 98
02-06-2013, 08:32 PM
(This post was last modified: 02-06-2013, 08:42 PM by xhelion.)
Hey all,
I want to lower my 306 dturbo and wondered if you can replace the torsion bar for a firmer one because if i lower it i don't want it to be impracticle with body rub etc?
Found out the biggest is 25mm if anyone needs to know
Threads: 169
91
There was a group buy a little while ago that went to 28/30 mm iirc
Threads: 198
135
Nah, thickest torsion bars we got were 25mm. ARB's went up to 30mm.
You can fit thicker than 25mm torsion bars but you need to dismanltle the beam to fit them.
Threads: 55
17
Car Model/Spec: 406 V6
25mm are pretty damned stiff though
Xsara VTS should have stiffer bars in the back than your dtub, fit some of those.
Threads: 198
135
I have 25's in mine, raised the ride heiight about 2" with the same damper bolt distances
Threads: 202
58
23.5 is just nice on mine, corners so flat but stays comfy
Threads: 208
60
Gti bars would be enough in a DT IMO. You wouldnt get any rub
Threads: 2
04-06-2013, 03:56 PM
(This post was last modified: 04-06-2013, 04:04 PM by xhelion.)
All right thats great so gti or 23's should be okay to strait swap in and out?
and also will i have to change anything else to accompany it?
Threads: 226
24
Car Model/Spec: A3 TDi
After a certain size they dont fit without modification, but up to that size its easy in and out. Although thats easier said than done.
Threads: 136
(04-06-2013, 07:20 PM)Tom Wrote: After a certain size they dont fit without modification, but up to that size its easy in and out. Although thats easier said than done.
And that certain size is 23.5
Threads: 208
60
Stop kidding yourself therr is no easy in & out when it comes to PCG rear beams that are 11-18 years old lol
Threads: 202
58
Yeah , 23.5 fits, but keep the paint thin  I'm being serious, they are CLOSE!!
Threads: 198
135
Aw wait, yeah I have 23.5's in mine, i forgot aha. But yes it's awful snug. The splines are thicker than 23.5mm but the grooves between the splines aren't.
Threads: 202
58
Yeh if you look at mine there's grooves in the paint
Threads: 208
60
(05-06-2013, 07:59 PM)Jonny81191 Wrote: Yeh if you look at mine there's grooves in the paint
See this is why you have to be sensible like me and mask up and spray them after fitting
Threads: 198
135
(05-06-2013, 08:37 PM)puglove Wrote: (05-06-2013, 07:59 PM)Jonny81191 Wrote: Yeh if you look at mine there's grooves in the paint
OR.. the finished bars still get the paint scraped off them because for some reason they painted the ends too when they made them
I adjusted the height of mine on Sunday and they were an absolute ballache to get out
Threads: 208
60
(05-06-2013, 08:39 PM)cwspellowe Wrote: (05-06-2013, 08:37 PM)puglove Wrote: (05-06-2013, 07:59 PM)Jonny81191 Wrote: Yeh if you look at mine there's grooves in the paint
Was that greased aswell?
Threads: 198
135
Mmhmm, i had to use an impact gun and a high tensile bolt and spacers to pull the bars out. Also needed to cut the thread again for the end bolts. Machining work really wasnt up to much tbh, maybe it was just mine
Threads: 202
58
Really Chris? That's a ballache, might pull mine just to keep them free then.
Threads: 198
135
Yeah, when I unscrewed the torx headed end bolts i noticed the threads had been flattened, so had to re-cut the threads in the bars or I couldn't wind an M8 bolt in to pull them out...
Threads: 202
58
Hmm, did you fit them?
