	Threads: 40
Car Model/Spec: Moonstone Ph3 GTi-6
		I want to know if this would also fit. Would be a total monster if it did, I assume?
	Threads: 79
17
Car Model/Spec: Down and out HDi racestate
		Is that a 2.2? The only difference is the bottom end isnt it? Which was brought up in another thread, would need the mapping changed to suit but it should fit
	Threads: 59
		Just a bottom end then, has anyone fitted one of these and tuned?
	Threads: 91
12
Car Model/Spec: 306 D Turbo
		If your going to do it then why not use the 2.2 16v?
	Threads: 59
		Because I didn't know there was one? haha
	Threads: 117
119
		Afaik the 2.2 16vs are all multiplexed, much bigger pita to transplant as a result. Pity, otherwise theyd be ideal.
	Threads: 91
83
		They're also significantly bigger, mounts are different... Turbos don't fit as standard...
The 2.0 16v is a better option and the 2.0 16v as STANDARD is as powerful as the 2.2 16v... And it's got a better turbo...
They also now do a 163hp and a 200hp 2.0 16v now also...
If you look on ebay you'll also notice you can like get a job lot of ex-taxi engines perfect for a rebuilt for £fuckall.99
The one shown isn't a 2.2 - that's a boggo 2.0 8v... Also with regards to management, use a 2.0 16v on Bosch management and re-map the Original 8v management to suit.
 (16-05-2016, 10:45 AM)Toms306 Wrote:  Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
	Threads: 7
Car Model/Spec: hdi estate
		Can you put the 16v head on the 8v block or is better just swap the engine
	Threads: 91
83
		If you're interested, yes it does work putting the 2.0 16v head on the 8v bottom end, but naturally yes, pistons need changing.
Remember there's a Siemens and a Bosch injected 2.0 16v HDi - you want the Bosch one... Easily distinguishable by the fact that the Bosch ones have ally inlet manifolds, the Siemens ones have Plastic inlets.
