Threads: 25
Car Model/Spec: Dturbo
Does an exhaust have to have any flexibility in it?
The standard exhaust has a small amount where the front pipe meets the turbo but is it absolutely necessary?
Threads: 226
24
Car Model/Spec: A3 TDi
Yes because the engine shakes on idle and rocks around when your on and off the power, so if it was solid you might snap your shit up!
Threads: 19
Car Model/Spec: Ph1 D-turbo(on going project)
if you dont want to use the standard pug one however you can put a universal wire wound jobby in on the downpipe or around there..
Threads: 25
Thats what i have on at present but i was just going to be lazy this time and fabricate up a solid pipe.
The standard one is too restrictive so il just just reuse the flexi pipe thats on the car at the minute.
Cheers lads
Threads: 42
Car Model/Spec: 1.9 XUD
Mine is solid at the minute (giggidy) and it is not actually a pain to live with.
But yeah, needs a bit of flex in ideally.
Threads: 25
Nah its no hassle il probably salvage the flexi from the exhaust that is on at present.
I just wanted to be able to make the new exhaust without having to remove the old one until it was time to fit the new.... lazy lol
