Threads: 1
Hi having problems with my ecu, fitted a new engine and started 4 times great then stopped had no spark or injectors so i assumed the ecu had locked,
so bought a unlocked ecu and great started first time did the same again but after 6 starts so im suspecting the loom is shorting the ecu? can anyone help me?
cheers aled
with the ecu that youve just fitted, take the battery off, leave it 20-30 minutes and put it back on then see if it will start. let me know the answer
Threads: 1
13-12-2012, 07:29 PM
(This post was last modified: 13-12-2012, 07:38 PM by pug306dts6.)
already tired still the same
ive changed the crank sensor and cleaned the earths and changed the fuel relay :/
hmmm ok. was it running slightly rough or missing before it packed in?
Threads: 1
nope was running great, this is why i stick to my good old XUD's!! haha
(13-12-2012, 07:44 PM)pug306dts6 Wrote: nope was running great, this is why i stick to my good old XUD's!! haha
tbh normally the gti ecu is very reliable. Does sound like something is damaging the ecu. Id check round the bay for any obvious trapped or damaged wires.
Threads: 1
yeah there is a crack on the hard plastic by the ECU plug, is it the same loom as an XSI? got plenty of them
nope unfortunately not. needs a gti loom unfortunately.
Threads: 115
26
Car Model/Spec: 306
I have a loom and ecu set and plenty of other parts if you need anything let me know
Threads: 1
13-12-2012, 10:42 PM
(This post was last modified: 13-12-2012, 10:43 PM by pug306dts6.)
damm, ive got 10 306's for breaking and nothing gti6 left.
(13-12-2012, 09:00 PM)spike2002 Wrote: I have a loom and ecu set and plenty of other parts if you need anything let me know
how much you asking? is it unlocked?
Threads: 115
26
Car Model/Spec: 306
(13-12-2012, 10:42 PM)pug306dts6 Wrote: damm, ive got 10 306's for breaking and nothing gti6 left.
The ecu isnt unlocked but i have all the parts ecu, chip from key, ring around ignition and the black box from the centre console of the dash £35 posted
Threads: 1
(13-12-2012, 10:54 PM)spike2002 Wrote: (13-12-2012, 10:42 PM)pug306dts6 Wrote: damm, ive got 10 306's for breaking and nothing gti6 left.
Yeah ok, how do you want you money paypal?
Threads: 115
26
Car Model/Spec: 306
Yes mate paypal is fine get 10 posts and drop me a pm and we will sort it out
Threads: 58
Car Model/Spec: Loads
The ECU will lock if you have the security in place still, the amount of times varies
Threads: 1
(14-12-2012, 12:12 AM)miles Wrote: The ECU will lock if you have the security in place still, the amount of times varies
cheers! im really puzzled ive looked at the loom and i cant find anything wrong, the security was still pluged in with the unlocked ecu,
Threads: 115
26
Car Model/Spec: 306
If the security was still in place most likely locked the ecu out
Threads: 1
20-12-2012, 12:15 PM
(This post was last modified: 20-12-2012, 12:19 PM by pug306dts6.)
ok ill try another ecu hope it dosent blow another!
would you sell just the ecu? ive gone through my loom and it looks fine
Threads: 115
26
Car Model/Spec: 306
20-12-2012, 01:25 PM
(This post was last modified: 20-12-2012, 01:26 PM by spike2002.)
Yes mate that's what the price was for before the ecu and all bits so it will work in your car black box exc
Its all matching so should be plug and play
Threads: 1
ok cheers ill get posting haha
Threads: 1
might sound thick? but why are you suposed to change the steering rack to fit a gti6? mines fitted fine and ive fitted gti6 racks to dturbos?
Threads: 115
26
Car Model/Spec: 306
20-12-2012, 02:50 PM
(This post was last modified: 20-12-2012, 02:50 PM by spike2002.)
The gti6 doesn't have as good a turning circle due to the 6speed box. If you don't fit a 6 speed box you will be ok but if you do and don't use the rack you may get rubbing
On full lock
Threads: 82
14
Car Model/Spec: P0XY Ph2 Dtub 5dr
Can't beat a good bit of rubbing
Threads: 1
20-12-2012, 05:08 PM
(This post was last modified: 20-12-2012, 05:13 PM by pug306dts6.)
oh right i knew that i thought there was some other reason haha, they rub anyway? haha
could do with a rack for my 205 with weller 10j's on it that rubs real bad! ive had to weld a ware plate on the end of the box
Threads: 58
That's why then, the Security must be unplugged as the different ECU confuses it and it will lock again, if you have the old car you can still unlock the old ECU But I doubt it's around anymore, Or get the security box with the ECU and off you go
Threads: 1
cheers i just didnt think, should be getting one soon
Threads: 115
26
Car Model/Spec: 306
Payment received mate will get it in the post for you
Threads: 1
spot on how much was postage in the end?
Threads: 0
Car Model/Spec: 1998 1.8 xt auto
Hi, I need an ECU for XU7JP 1.8 xt, 8v, Magneti Marelli IAW 8p.1a. Better still if the whole kit is for sale.
Thanks!
Threads: 77
15
Hit it with a hammer
Threads: 0
14-03-2013, 03:58 PM
(This post was last modified: 14-03-2013, 04:01 PM by tgs.)
(13-03-2013, 08:44 PM)sam Wrote: Hit it with a hammer
I might!  Is it true that a IAW 8p 1a can be replaced by a IAW 8p 10, provided that the decoding is done and the memory chip is ported over from the nonresponsive ECU?
Thanks!
