	Threads: 16
1
Car Model/Spec: Supercharged Gti-6
		Clutch has always been heavy on my stage 1 hdi so knew it was on its way out but just begun to slip under full load the other day. I work or a Citroen Peugeot garage and we have a new valeo clutch kit for a 306 s16 kicking around. Valeo part number is 821087. (pull type)
Anyone know if this would fit my 306 hdi and handle the torque of a stage 1 approx 120-125 BHP.
I've heard of gti clutches wing used before but not s16.
	Threads: 82
27
		I don't believe they're the same and the HDi is a push type gearbox
	Threads: 16
1
		Later ones are push with hydraulic slave cylinder earlier ones are pull I believe? I'll have a look at it later. All gti-6's are pull type so for people to fit them to a hdi they must be pull.
	Threads: 117
119
		No. 306 hdis never had hydro clutches. Hdi is a push type, to use a 6 clutch it needs to be converted to pull type.
	Threads: 16
1
		Ahh change forks etc. just had a look and it's a cable type as said. Will get one in from gsf or similar then cheers.
	Threads: 91
83
		S16 clutch has a slightly heavier pressure plate, but is essentially the same as a GTi6 clutch or XUD9 clutch...  It'd fit if you did a clutch conversion to pull type... But not as standrlard.
 (16-05-2016, 10:45 AM)Toms306 Wrote:  Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
	Threads: 117
119
		You've got it. There's a bloke on here that says he's using a '6 clutch with a stage 2, so got to be worth doing the conversion imo, should theoretically hold stage 1 power as long as you like.
	Threads: 91
12
Car Model/Spec: 306 D Turbo
		I've got a 6 clutch and flywheel setup on mine with a low torque map and it holds fine
	Threads: 16
1
		Well I've got a standard valeo 6 clutch on my supercharged 6 with a lightened flywheel and crank pulley running 260bhp and doesn't slip at all so their pretty strong.
	Threads: 117
119
		Its not the horsepower thats the issue, its the torque - sc torque is much more progressive so easier on the clutch.
	Threads: 117
119
		Haha random, they do seem to last forever if well looked after, my 185k car is on its original and im fairly sure its been abused lol.
	Threads: 16
1
		Yeh just Thursday I did a clutch on a 206 2.0 hdi and it had done 199003 miles lol
