ph3 on ph2 headlights
just a quick one, do the phase 3 headlight fit the phase 3,
cheers now
Yeah direct fit x
306 HDI, soon to be XUD
Yes. Big Grin they will but you'll have to swap the adjusters
They fit fine, though you'll need to swap the adjusters from the phase 2 lights onto the phase 3 lights (so your headlight adjuster in the cabin still works), and possible the headlight stalk.
Swap the headlight stalk if you want the crystals work properly.......dipped stays on with main beam if you have a Ph3 stalk, without it dipped will turn off when you change to main.
