	Threads: 162
21 Location: Dunstable
 Thanks: 0Given 23 thank(s) in 23 post(s)
		What penetrating oil do you guys use?
 I've used plus gas but I don't find it too good and I've heard good things about Q10. Has anyone here used this stuff?
	Threads: 289
92 Location: London
 Car Model/Spec: Phase 17 R26
 Thanks: 0Given 1 thank(s) in 1 post(s)
		Inb4Samass/giggidy
I use 3-in-1
	Threads: 541
124 Location: Aylesbury
 Thanks: 7Given 59 thank(s) in 58 post(s)
	Threads: 162
		03-03-2013, 09:50 PM
(This post was last modified: 03-03-2013, 09:51 PM by DeeTurbo.)
		Is 3-in-1 not a little too thick to work as a penetrating fluid?
	Threads: 289
92 Location: London
		There are a few different ones though, the orange one is penetrating spray.http://www.halfords.com/webapp/wcs/store...yId_255223
	Threads: 55
17 Location: Rotherham
 Car Model/Spec: 406 V6
 Thanks: 3Given 10 thank(s) in 10 post(s)
		Plusgas.
Custom roll cages/shiny suspension bits/general fabrication work undertaken, PM me.Top engine mount repair/reinforcement/chocking for cracked chassis and high powered cars, drive in, drive out, 2 hour turnaround.
	Threads: 78
49 Location: Chichester
 Thanks: 0Given 0 thank(s) in 0 post(s)
		As the thread that was just up about this, Plus Gas. Can't fault it.
	Threads: 130
82 Location: Kingston
 Car Model/Spec: 106 GO-NAD
		Yeah, another plus gas vote, bit, the 3 in 1 stuff is pretty good, but plus gas is better I find
	Threads: 78
		If it's something you know is going to be trouble, soak it in advance to give it a chance to work
	Threads: 162
		03-03-2013, 10:04 PM
(This post was last modified: 03-03-2013, 10:05 PM by DeeTurbo.)
		 (03-03-2013, 09:54 PM)Scott Wrote:  There are a few different ones though, the orange one is penetrating spray.
Oops thought you meant the multi purpose oil.
  (03-03-2013, 10:04 PM)Curt Wrote:  If it's something you know is going to be trouble, soak it in advance to give it a chance to work
Very true, planning ahead and all that.
	Threads: 117
119 Location: Southampton
 Thanks: 13Given 106 thank(s) in 106 post(s)
	Threads: 202
58 Location: Eastleigh
 Thanks: 2Given 29 thank(s) in 28 post(s)
		I normally make the offending item hot with a blowtorch. Then spray it with whatever I have lying around, usually wd40 or gt85 while it's still hot. Seems to do the trick.
	Threads: 208
60 Location: Wiltshire
 Thanks: 1Given 5 thank(s) in 5 post(s)
		Plus gas & 3in1 (orange can)
![[Image: DSC_0190-Copy_zpsf093f84d.jpg]](http://i1038.photobucket.com/albums/a468/167gti8/DSC_0190-Copy_zpsf093f84d.jpg) Member of 99% warning or your nothing club!
	Threads: 151
14 Location: Rotherham
 Car Model/Spec: 306 D-turbo
 Thanks: 1Given 0 thank(s) in 0 post(s)
		Elbow grease works well for me
![[Image: image_zps45f2003b.jpg]](http://i39.photobucket.com/albums/e174/austinmini-2008/image_zps45f2003b.jpg)
Team Doesn't own a 306
	Threads: 186
38 Location: Manchester
 Car Model/Spec: MG ZR VVC
 Thanks: 3Given 21 thank(s) in 19 post(s)
		a bit of spit gets things moving for me
	Threads: 94
7 Car Model/Spec: 205 coming soon
		KY jelly does the trick when I'm penetrating
Official Team Go-NAD fan club
	Threads: 29
39 Location: Weston-super-Mare, Somerset
 Car Model/Spec: Ph 2.5 Nile Blue GTi6
		I heard using sand helps?
 I mean those VTEC boys can't be wrong.
	Threads: 591
54 Location: Cotswolds
       Thanks: 22Given 68 thank(s) in 68 post(s)
		Double TT
 half price of wd40...twice as good
	Threads: 169
91 Location: South London
 Thanks: 1Given 1 thank(s) in 1 post(s)
		Astraglide
 /thread
![[Image: car-1.jpg]](http://i1117.photobucket.com/albums/k591/grant-306/car-1.jpg)  Member of the 99% warning or you're nothing club
