	Threads: 52
1
Car Model/Spec: Ph2 Dturbo
		well as usual the air con in my car doesnt work,
ive checked it and its degassed. so whats the chances that is just dissapered and can be re gassed without leaks? or where is the most common place for it to leak?
OR
I remembered some one doing a guide how to swap some wires so that the air con button made the cooling fans come on at full power.
anyone remember how?
thanks alot
Diggers
	Threads: 465
114
Car Model/Spec: Vauxhall
		22-02-2013, 11:47 AM
(This post was last modified: 22-02-2013, 11:47 AM by cully.)
		kwik fit used to do a deal if it couldnt hold pressure they wouldn't charge ££ on a regas
most common point is the pipe along the front crossmember under the rad
saying that though the condensor on mine was holed
	Threads: 52
1
		Now down kwik fit. They pressure test it. If it leaks it's free. If it holds then 29 quid for regas and 30 day money back if it drains. Got me in straight away.
	Threads: 52
1
		Does the air con model have a pollen filter or where none ever fitted with one.
	Threads: 52
1
		Well it pressure tested fine. Now re gassing
	Threads: 465
114
		only euro cars were fitted with pollen filters no uk 306's
