19-02-2013, 01:41 PM
hey just a quickie, when i brought be hdi a month ago therewere a no. if isses to sort out, most are dont only things left are abs light and hand brake light, i check the fluid level incase it was that, then pulled the hand brake switch, when i tested it with a multimeter nothing happen (switch wise). so i brought another.....only issue is wheni took the plug off the connetor dropped to into the hole of all things lost. i pulled 1 through but ive lost the second one........now the question i have is are there definately 2 wires going to it, and anyone know where they run to...... the wire i have recovered runs under the drivers seat....easy the secont is lost for all eternity, i looked with a torch from the back through the hand brake assembly and cant see anything......except and joint lol
any ideas?
cheers
any ideas?
cheers
