16-02-2013, 08:31 PM
I did the drivers side wheel bearing on the 306 HDI a little while ago, then about 3 weeks later a funny noise started when turning ,so had a quick look only to find the drivers side spring snapped, so had both front springs replaced while the car was in having the springs done, the garage phoned me and said that my front pads were almost totally worn out (i knew they were as i was planning to do them) so they replaced them for just the cost of the pads.
Now the car just does not feel right to me, under heavy braking it seems really unstable and pulls to the right and under hard acceleration the drivers side wheel seems a bit strange and it tends to follow the camber of the road a lot more ( i hope this makes sense), i had a quick look under the car couldn't see anything obvious only thing i noticed was that the drivers bottom ball joint the boot was split and grease was all out of it, so if that was knackered could that cause it?? But i bet they split that when they were doing the springs.
Thats why i hate taking my car to the garage but i just didn't have time to do it myself, i had it done at a garage down near where i work ( 150 miles away from me now) i will be popping in to see them the week after next when i am back down there, but going to have a look around the car tomorrow as i have a few other bits to do to it and was after a few suggestions of what to check.
Thanks in advance fellas
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg)
