MBC
I have a manual boost controller put onto my turbo. Ill be fitting the boost gauge in the next couple of days. But dors anyone know what psi it will be making as standard?
around 12-13psi I think? Been so long since going in a stock diesel Big Grin Your boost may be limited by your fuelling OR your wastegate ...
Aye, 12 to 14psi is standard. With your pump its gona be the wastegate limiting boost!!! If I were you I'd fit the boost gauge first then the mbc so that you know what you're running!
What harkey says
Make sure the boost guage is on and working before you play around with the MBC
Bear in mind you'll need to up the fuel to get the best
