options for key plip?
Since I bought my ph1 dt the remote central locking didn't work. Works with key in door I've changes batterys no better the key is faulty in some way . How do I go about getting some sort of rcl to work .
New internals? New plip and infared sensor?
Thanks
plip is a new one. So it will lock all of the doors if its in the lock? Probably best to look at the door loom anyway seeing as it causes so many problems!
Reprogram a known working phase 1 or 2 key easy done I have just reprogrammed a phase2 key to my phase1 only took a minute to do easy Wink
(07-02-2013, 08:04 PM)spike2002 Wrote: Reprogram a known working phase 1 or 2 key easy done I have just reprogrammed a phase2 key to my phase1 only took a minute to do easy Wink
You can buy working keys off Ebay refurbished or other wise.
When you get them take your phone camera and see if you can see the infra red blip from around the sender.
