You Know Your Car Is Low When...
...you need to drive up a curb to give you enough height to change a foglight bulb.
You swerve around cats eyes
When there's a trail of sparks following where ever you go
Official Team Go-NAD fan club
Wen it takes 30minz 2 get off your driveway!!
When you have to know a specific "route" (swerving) along back roads to avoid bottoming out Big Grin
When you can't drive up a kerb to try and get enough height to change a fog light bulb..
When you can't have too many passengers or you'll scrape the bumps.
When traffic police cant get at your front tyres to test the tread depth
When you cant drive over a red bull can rolling on its side on the road without pushing it for a mile with your splitter.
When you cant parallel park with your door to the kerb otherwise you cant open it
When your driver side rear wheel arch is scraping.
When you need two jacks to jack up a car, or a strong dude to lift it up!
I still havent fixed that.
When it rides lower than my nans nipples.
When your departure/approach angles are so narrow steep roads can be an issue. Beached the van on sleeping policeman and loading bay ramps before too lol
(27-01-2013, 01:20 PM)bigcheez2k3 Wrote: ...you need to drive up a curb to give you enough height to change a foglight bulb.
when you cant drive up a curb at all
You take a steep surface at an angle and start balancing on 2/3 wheels.
when your irish.
When your splitter is a few centimetres thinner than when you first fitted it as its worn away over time on driveways, curbs and speed bumps
When you change your sump 3 times in 1 year.
And when you laugh at people that think 60mm is low.
when ur splitter scrapes off the ground constantly even on the motorway.
when u bend the cradle by hitting a stone on the road.
when your front bumper hits the floor without a fake low on(spilitter)
When you rip your fuel filter off on a cats eye
When your wheels are sitting that low in the arches you go to set off and all for wheels are off the ground and your beached on a flat road
When you show everyone a builders arse when you get in or out.
It takes you 30mins longer to go round due to not going over a speed bump
When you hit a cats eye and your airbags and per-tensioners go off Smile
[Image: 704e7db1.jpg]
When yer car is f*cking useless as a mode of transportation?
when you realise you're car would be quite an efficient snow plough
when you cant get to your own house because the drive is too uneven
You take every speed bump at normal pace and removed pieces of splitter/bumper/exhuast/heatshield in the process.
Only 40mm as well, dunno how people can be arsed with actually low cars! lol
when you have to drive onto a stone or wood to get a jack under neath
when you can hear your plowing snow
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
(27-01-2013, 06:54 PM)karl1989 Wrote: when you have to drive onto a stone or wood to get a jack under neath
Smart! Ill put that into practice.
Usually i would pull the T-jack out the boot(or whatever its called), jack it up a little with that then the big jack!
would take me an hour getting it back in its place.the T jack that is.
I always drive up onto bricks before jacking the van up, used that trick for years.
