xud9 in a 205?
I know its been done a few times before, but I've still got a few questions.
am I right in thinking they have the same mounts, a xud7 205 -> xud9t
and I'm guessing the tmic won't fit under the bonnet of a 205?
basically seen a 205 localish in need of not too much love, and for a good price, and also I'm in need of some diesel boost, had a want for a 205 for ages ever since I wrote mine of 8 years ago ....
[Image: signiture.jpg]
The tmic does fit under there. Have seen it done. (Not sure if raisers were needed though
Again not sure on the mounts though but I'm sure Mr Tait may be along to give you the lowdoen
ah cool will have a trawl through his thread at lunch tomorrow, is pipe dream atm but if the car in question goes cheap enough could be a fun little project
on tmic front thinking about it would be a bad idea, they're bad enough with a good bonnet lining in a 306 let alone without any!
Strictlyderv will soon be along to answer your questions I'm sure, or give him a pm
engine mounts are the same; yes, but probably worth replacing them
TMIC i believe you'd need an auto bonnet, or take my route, SMIC.
i am just about to start this i think im going to raise the bonnet to start with.
i am going to use the 1.9 gearbox can i use the 1.8 dturbo driveshafts??
power steering use a saxo powersteering pump??
I'm pretty sure gearboxes are interchangeable so I'd assume so are drive shafts? correct anyone?
power steering? why would you need that?
how do you mean an auto bonnet?
stayed up late reading through strictly_derv's thread I'm very keen on this idea, after all everyone needs 2 cars!!
(17-01-2013, 12:22 PM)kernow_joe Wrote: I'm pretty sure gearboxes are interchangeable so I'd assume so are drive shafts? correct anyone?
gearbox is fine, use the XUD9 box, as for the shafts, i believe the 1.8 shafts are fine. I'd suggest keeping both sets, and see which works
get rid of it and use the 1.8 AUX setup
the automatic 205's have a raised bonnet, see strictly_dervs new bonnet, it's raised, it's called an auto bonnet as it's from the automatic 205's ; the engine sits slightly higher i believe? either way, a bit more roomy
Hope that helps.
EDIT: [Image: %24T2eC16ZHJHQE9nzEy8GmBQ5tHlVmsw~~60_12.JPG]
Auto bonnet; but would probably have poor air flow to it.
XUD9's won't fit, you need custom engine mount holder welded in and drive shafts. Not worth it. Dodgy
Stage 2 XUD Sedan
(17-01-2013, 12:38 PM)strictly_derv Wrote: XUD9's won't fit, you need custom engine mount holder welded in and drive shafts. Not worth it. Dodgy
XUD9 shafts? ... not the engine itself? Huh
Yep,, custom shafts will be needed.
Stage 2 XUD Sedan
so you cant use the 1.9 gearbox with 1.8 driveshafts??
"custom" shafts for this application can very easily be made at home, nothing "custom" is needed, simply bits from different shafts combining Smile The stock GTI ones like to break lol!
[Image: sigi-2.png]
so if you stick the 1.8 box on standard 1.8 drive shafts can be used?
if you go 1.9 box 'custom' shafts needed, ie half one and half another standard shaft?
@ginge : great help, cheers bud
What gearbox are you using??
Problem with the TMIC is not so much fitting it, it's getting airflow to it.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
[Image: 33521994.jpg]
lmao
I think he was talking about the shafts, as darren says...
You will need machined ones. Darren, what would you know aye?
Stage 2 XUD Sedan
Well I have a 205 field car, which we put a gti6 box on, and with some parts from a 309 there was no issues at all. max spend is like 20 quid and greasy hands.
[Image: sigi-2.png]
Hah love trollin'
Serious note, the standard shafts do fit 306 box's no problem.
Stage 2 XUD Sedan
lol you bastard! I was a bit confused, but taking your word for it!
all sounds like a nice easy job then.
not that its overly important but what about dash electrics/speedo, did I read you haven't got a speedo is that for other reasons?
I do now, it stopped working 2 years ago and got it working again not long after think the cog got worn.
Stage 2 XUD Sedan
ahh shit just put a downer on me!! i was supposed to be converting in 2-3 weeks looks like i need more research Sad
Official Team Go-NAD fan club
you can put XUD9 into the 205 ... i ve done it! .i split the shafts so 405 into gear box and keep the 205 outerdriveshafts..Same mounts and tmic fits under standard bonnet.
So sounds realy easy to do then xud9 engone and box with xud7 driveshafts.
does the standard 205 exhaust downpipe meet with the turbo?
strictly derv: Have you had to cut/smash the bulkhead back o fit a bigger turbo.
what have you done with your power steering just left the pipes off??
(18-01-2013, 09:42 AM)aggyj17 Wrote: strictly derv: Have you had to cut/smash the bulkhead back o fit a bigger turbo.
No smashing, the engine bay has a fair bit more room. Even with the '25v i dont think he/we are going to smash it at all...
(18-01-2013, 09:42 AM)aggyj17 Wrote: what have you done with your power steering just left the pipes off??
(17-01-2013, 12:31 PM)ginge191 Wrote: [quote='kernow_joe' pid='197282' dateline='1358425354']
oh right its just that when i have seen td04's in a 306 the bulkhead needed a bit on modifying lol.
I know that kernow joensaid sack it off but do you change to a non pas rack or just disconnect the pipes???
if you're not using it no point having a heavy pump there is there Smile
(18-01-2013, 11:02 AM)aggyj17 Wrote: oh right its just that when i have seen td04's in a 306 the bulkhead needed a bit on modifying lol.
(18-01-2013, 12:49 PM)kernow_joe Wrote: if you're not using it no point having a heavy pump there is there Smile
As for the turbo; this is true with the 306, but the 206 is not a 306 Big Grin It, believe it or not, has a lot more room towards the rear. Either because the bay is larger or the engine sits further forward; im not sure.
