Abs module
Hey just a quick question is the module for the abs build it or is it seperate, my abs light is on and had a mate scan it for codes, but it wouldnt communicate, so iam guessing the module is foooooked. Anyone know?
Built in mate. Its all in the pump behind the N/S headlight.
And it might not be buggered. These cars arnt truely OBD compliant so some scanners wont work with some bits. Im assuming youve got the light on on the dash? If so, its more than likely a wheel speed sensor which are very easy to test with a multimeter and something metal.
Good to know, if spin the wheel i should see a fluctuation on the multi meter, good shout cheers, i used a snap on one it comm'ed with the ecu so took a stab at it, but ill try that first cheers
yeah set your meter to AC and spin the wheel slowly and you should see it pick up a small voltage as the raised parts of the ring pass it.
